I have been asked with the following question regarding the design of a pumping system for a potable water pipeline, and I have several questions which I hope can be cleared.
Here's the question:
The pipeline is to transfer bulk water supplies from the treated water tank, at the outlet of a new treatment works, to a service reservoir about 35 km away. The water levels in the treated water tank vary between +31.0 and +35.0 mAD and the delivery level at the service reservoir is +116 mAD. (see attachment)
The project is to be developed in two phases. In Stage 1 the maximum flow requirement is 75 Ml/day. In Stage 2 this will be doubled to 150 Ml/d. The client has specified that he must be able to transfer any flow up to the maximum at each Stage.
The preliminary design report carried out by the client’s engineer recommended a minimum size of pipe of 1200 mm and the Terms of Reference specify that the pipe shall be cement-lined ductile iron, and be capable of passing the maximum flow with a possible roughness of 0.6 mm.
I am also attaching the longitudinal profile given.
Here are my considerations for the solution:
- I would install two reservoirs: one at the very beginning and another one at the first higher pic of 149 in order to make sure the velocity established is fulfilled.
- In the first reservoir I am planning to install 3 horizontal centrifugal pumps in series (would need some help on getting pump catalogs!)
- On the second reservoir, I would put the reservoir at least up to 165 m above the pic to enable gravity forces to come out.
- Since it is an open tank system, I would use variable speed valves at the beginning and close valves right before the last reservoir to prevent surge problems, although I am not sure about it.
- In order to draw the gradient line, according to the designing made, I have taken into account the first elevation of 31 and the system head calculated on this first part, and the same applied to the second.
My main question arises of the whole justification of the system designed, since I find it hard due to the lack of information given to, for instance, justify the pumps duty and the different protections needed.
Any help or tip on that would be really appreciate it.
Best Regards
Walt.
Edited by Felina, 06 January 2014 - 03:20 PM.
