I've unprotect, unfrozen panes, and tried everything to get this workbook to work properly, but I simply don't have any luck. The text boxes are misaligned, buttons don't seem to work. I'm running Excel 2007 on Windows 8. My inability to properly evaluate the spreadsheet is why I haven't posted it in the Download section.
Yes I know that as u already mailed me in that aspect,
I m sorry in that aspect. But I think that if u r facing everything misaligned then u probably have zoomed in or out. In 2007 it would work only with 100% zoom. Check ur zoom bar in the status bar at the bottom of excel.
Also Here I have added a new file in the first post of this thread with all sheets unprotected and unfreezed, the only problem now would be, that if someone accidentally changes the formulas, he would blame me in the end that my app is flawed
hmm, can't download, the link is dead
Dear, I just checked the link and its perfectly working. Kindly check again.
Celopsin,
I had the opportunity to quickly review your worksheet and I've appreciated some good aspects and highlighted some areas of "naivety".
I encourage you to go ahead by this way and propose other worksheets to the community.
Some outcomes and comments of my review are listed below:
- the overall aspect is very clear. You've visually differentiated input cells from calculated ones and calculations cells are protected.
- the choice cells for the unit of measures are a plus (but sometimes they create confusion...)
- you can improve the visual understanding of the data by showing only the meaningful number of decimals
- K, kg/m2, J/s.... are not used by engineers
- there's no added value in showing g=9.8
- you should state (in the help section, for instance) that the worksheet is only suitable for single phase flow and one shell only. They're quite significant limitations
- all the links seems working (I don't understand Chris comment on this aspect)
- the references and equations are documented and clearly written in the help section
I hope the above is helpful to you.
Good luck!
Thanks gegio1960,
I really wanted someone to tell me that as my teachers and mates were too busy reviewing my work
. You are very right about your comments, I made this app with little knowledge of Shell & Tube Heat Exchangers in my 5th Semester, 3rd Year of Chemical Engineering (now I m in my final year searching jobs) and in the process of making this app (i.e 44 days) I learnt much about Shell & Tube Heat Exchangers.
I started this work, with just a urge of solving a Numerical Problem (Example 8.2 of Binay K. Dutta) and later I added conditional formatting and auto indexing of the Shell Dia (which was the toughest part) ... I added the choice of units not keeping in mind that this would be used by engineers, I just opened Hysys and checked different sets of units and hence added mine
. Later I added an interface to this app which I created in Adobe Photoshop.
So this was how I made it. I shared it only when this forum wont let me see any download links
and required me to post first. So I thought of sharing this (else I thought, as 1 yr has passed, that this is completely useless work)
I have a few other excel sheets too as I try to solve my every problem on excel, but I havent shared them too as they have a limited context. They cant be understood by everyone as they are too complex with no proper interface, but they can tell u only that u can do anything with excel.
Thanks again
Edited by Celopsin.Khan, 18 March 2014 - 09:11 AM.
