Hi there,
I am having some problems understanding how flash separation works in HYSYS.
As attached in the picture, I have propylene oxide, propanal, acetone, methanol, water and 3 glycols (listed here in increasing component B.P) in my feed stream. In this flash separation, I want to flash out the lighter components - propylene oxide, propanol, acetone, methanol. The highest boiling point among these components is 64.7C (at 1 atm), from methanol.
My feed stream is coming in at 1 bar and 90C and I did not specify any pressure drop across the flash separator.
My question is - Why are all the components with boiling point less than 90C NOT vaporised and got separated in the vapour phase?
If I further increase the temperature/ decrease pressure, I would vaporise some of the water as well, which is not my intention as I want to get rid of the water downstream.
Thank you.
