Kiran:
PingPong rightfully points out the basic reasons why you should have a difference in price. You are making reference to what is a cryogenic valve design applied to an adiabatic expansion service. Please refer to the attached illustrations of a cryogenic valve design and note the difference in physical design.
- A normal throttling pressure reducing valve does not have to withstand the stresses and temperature differences imposed on a cryogenic valve;
- A J-T valve design is used as a by-pass around any cryogenic expansion engine or turboexpander because usually a complete liquefaction of the entire gas stream cannot be allowed to occur within the isentropic expansion device due to the formation of excess harmful/destructive liquid within the machine. Therefore, a J-T valve is applied to a part of the total stream – even though the adiabatic isenthalpic expansion is much less efficient than the isentropic expansion device doing useful work.
- In carrying out a J-T effect, the expansion valve is subjected to cryogenic temperatures and these require a special design that allows it to function normally when required.
- An extended stem is a physical requirement for any cryogenic valve in order to insulate the valve body from the required, ambient manual or automatic controls.
- Due to the cryogenic temperatures, the J-T valve requires exotic materials of construction (stainless steels) that will maintain their tensile strength throughout the cryogenic range.
I have used many J-T valves during my time and most have been encased in a cold box. The extended stem allows for this feature. I have specified and used a type of J-T design that I have found to be more functional than the usual. I prefer a 90o valve body design, with the inlet stream at the side of the valve body and the exiting, low pressure, 2-phase stream at the bottom of the valve body. This configuration allows me to orient the valve stem in a horizontal manner, allowing easy stem control and the resulting 2-phase stream to enter the vessel (distillation column, 2-phase separator, etc.) downstream with greater ease and less possibility of erosion, flow changes, and plugging due to formed solids (water ice, CO2, etc.). this configuration, of course, has its trade off: the extended stem design is subjected to the inlet pressure rather than the outlet pressure and consequently requires more robust design. But I have found this configuration design has justifiable merits in cryogenic and other refrigeration applications.
Cryogenic Valves.docx 207.92KB
174 downloads
