Dear all,
Need your help again please.
I have designed a valve using PSG8 [which more or less uses same formulas as that of API520] and supplier quoted a ASME VIII valve.
As we know the actual orifice area of ASME valves are larger than API valves. However, supplier is trying to explain that both valves are one and the same.
- However, I do not agree with supplier as orifice area of both valves are different e.g. ‘L’ orifice in ASME equates to 2118mm2 while that in API equates to 1840mm2. And I am wondering how can these two valves are same? I understand that it is better to install a valve with bigger orifice [ASME] valve but not sure if this is allowed?
- Also, I am checking pressure relief documents prepared by someone if past and it seems that he designed valve based on PSG8 and valve supplier has supplied ASME valve. Is this OK?
- Also, to my surprise, supplier has quoted ASME ‘L’ orifice area of 2078.06mm2 which is again different to standard ASME orifice L area stated above.
- Similarly, supplier has quoted ASME ‘J’ orifice area of 937.417mm2 instead of standard ASME area of 940mm2. Not sure how and why?
Any help please.
Thanks a lot.
Edited by chemks2012, 17 February 2014 - 06:19 AM.
