Hi all
I have a question to ask you all. I have a heat exchanger that fouls because of water at the tubeside and shell side. I have asked a few qoutation to clean the Heat exchanger. However from the qoutation i found out there is a bit of a difference. They both use pipes to poke through the heat exchangers however the water pressure jetting out from these pipe are different. One is jetting at the lower pressure at 8 bar while the other one is jetting out at 20 bar(which this is more expensive) I want to ask is there a difference between this two cleaning methods? what is the rule of thumb when you want to clean such heat exchanger? Does the design pressue of the heat exchangers matter?
sorry for this stupid question
Best Regards
