Hi friends is there anyone who know what does mean 'slip stream ' ?( the absorber column is designed to operate
on slip stream )
Thanks a lot
Posted 26 February 2014 - 02:30 AM
on slip stream )
Thanks a lot
Posted 26 February 2014 - 08:33 AM
Whether or not it applies in your situation I don't know, but usually I have taken this to mean a by-pass installation e.g. as commonly used for sample analysers, where flow returns to the main process pipeline, or it can mean a take-off line from the main process line.... what happens to the outflow is another matter - in some refinery analyser applications it goes to the "gutter" i.e. does not return to the main process pipeline (perhaps for reasons of pressure) but is instead discarded into the residues.
How To Remove The Condensate In A Wet Gas StreamStarted by Guest_ksagarzazu_* , 25 Feb 2025 |
Condenser Inlet Stream TemperatureStarted by Guest_Sampath123_* , 06 Jul 2024 |
Hysys Stream WorksheetStarted by Guest_nasim304_* , 22 May 2024 |
Need Help In Calculating Ammonia Slip In Scr Unit.Started by Guest_Redbull010203_* , 11 Mar 2024 |
Flow Tubing Head Pressure (Fthp) Definition ?Started by Guest_rs20170808@gmail.com_* , 31 Jan 2021 |
