Sizing Of Driver (Electric Motor) For Pumps
motor pump electric motor driver service factor refining
#1 ron23
ron23
Posted 26 February 2014 - 09:19 PM
Good day!
I am currently evaluating if the driver (electric motor) of a pump was sized correctly in terms of electric motor power output. I already computed the power requirement of pump at rated capacity. In line with this, what factors do I need to multiply with the power requirement to calculate the required electric motor power output?
In one literature that I have read, power requirement is multiplied by service factor and safety factor (set by American Petroleum Institute for refinery applications) to compute for the required electric motor power output. I would just like to know if this is true?
Thank you.
#2 Prasanjit
Prasanjit
  • 13 posts
Posted 26 February 2014 - 11:41 PM
Yes , if you go as per API 610 to calculate the power of the motor / driver, you would get the nearest exact power motor/driver.
#3 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 26 February 2014 - 11:44 PM
ron23,
After you have calculated the  BkW (Brake kilowatt) of the motor using the formula:
BkW = Q*ΔP / (36*Eo)
where:
BkW = Brake Kilowatt in KW
Q = Volumetric flow rate in m3/h
ΔP = Differential Pressure, bar
Eo = pump hydraulic efficiency
The BkW obtained thus needs to be multiplied by a load factor to arrive at the motor power. Load factors are typically 1.1 for centrifugal pumps and 1.05 for positive displacement pumps. Next round-off (round-up) the motor power to the next available standard motor size.
Edited by ankur2061, 27 February 2014 - 12:08 AM.
#4 breizh
  • 6,715 posts
Posted 27 February 2014 - 11:42 PM
ron 23,
On top of what is written above , consider this resource ( last pages with reference to ABB motor) with power factor indicated # 0.9
Hope this helps
#5 gegio1960
gegio1960
  • 518 posts
Posted 01 March 2014 - 01:13 AM
Attached File  sizing of electric motors for pumps.xlsx   27.73KB   95 downloads
#6 gegio1960
gegio1960
  • 518 posts
Posted 07 March 2014 - 01:30 AM
added the calculation of an estimate of the pump efficiency
Attached File  sizing of electric motors for pumps_r1.xlsx   28.26KB   91 downloads
