Hasan:
As I requested last month, what we need in order to discuss this topic in a clear, accurate, detailed, and positive manner without any mistakes or misconceptions is:
- All your basic data - complete with capacities and utilities identification; since you are not an engineer, this data is the capacity of CO2 (kg/hr) recovered from the flue gas, the CO2 purity sought, the storage conditions of the produced liquid CO2, the designer and fabricator of your MEA recovery plant process, the %MEA (wt.) solution used, the temperature and pressure of the MEA Stripper reboiler, the liters/min of MEA solution circulated, and the temperature and pressure of the gaseous CO2 exiting the CO2 cooler on the MEA Stripper outlet.
- A detailed flow diagram of your proposed process – complete with temperatures and pressures indicated.
If you are recovering the CO2 from an existing flue gas out of an existing boiler, you are going to require some low pressure steam for the MEA reboiler tube bundle in order to regenerate the rich MEA into lean MEA. I presume you are using some steam from the existing boiler.
What do you mean by a “header is made to remove any moisture”? You probably mean a vapor-liquid separator, since headers don't remove moisture. Your lack of process knowledge makes it important to have at least a detailed flow diagram before discussing your plant. Otherwise, we will spend a lot of useless and confusing time exchanging information among ourselves.
Your statement that your compressor has only 2-3 millibar (gauge or absolute pressure?) of suction does not make any sense at all. That is why I need to know who designed and built this small plant. If what you say is true, you are saddled with a ridiculous situation. As I have previously stated, if you are using a boiler to produce a flue gas that is treated with an amine solution ( as is the common, normal manner) to selectively capture the CO2, then you are generating 6-10 psig of recovered CO2 pressure (345 - 690 millibarg) in the outlet of the MEA stripper tower. That is a process fact. If your plant is wasting that available pressure, you obviously have a flawed and silly design.
I have always used ¼” activated alumina spheres in my CO2 adsorber dryers. If that is what you mean to ask, then that is my response.
I have always designed my CO2 adsorbers to generate a minimum of 500 oF in the regeneration gas. The regenerated bed should achieve a temperature of 450 oF. These temperatures depend on the type of adsorber dryer arrangement you have and the cycles you are employing. That is why I require a detailed flow diagram of the plant. Otherwise we are wasting time and effort in discussing something we don’t even have a decent description of.
Additionally, if it takes you 3 weeks to reply, consider that it may also take that long for our members to reply to you. If your need is not urgent or important, then please tell us. I have assumed your request to be a serious one and that it required timely response and accurate information. That is why my responses have been rapid and detailed.
