Piping Expansion Loops With 45 Degree Elbow Or 90 Degree Elbow
Posted 07 March 2014 - 03:54 AM
Posted 20 March 2014 - 12:50 PM
Viru,
It isn't a normal practice to do so, but appears using 45 degree elbows would create more room for pipe expansion provided that for such size there would be standard 45 degree elbow in the market...but stress analysis can specify if it is advantageous...
Edited by fallah, 20 March 2014 - 01:12 PM.
Posted 21 March 2014 - 12:40 PM
Viru:
As Fallah mentions, I have found that using 45o elbows has given not only more expansion, but the distribution of expansion stress has been much less severe and more evenly distributed. I’ve used it in pipe sizes up to 4”.
If we consider that an “omega” loop is universally used to ideally and evenly distribute expansion forces in piping, then we can understand that elbow angles less than 90o are a means to achieve something similar. However, bear in mind that like in all engineering solutions there is a tradeoff: you will wind up with more pipe welds and more expensive components (the hard-to-find 45o elbows). On the other hand, this is “big bore” piping and there may be favorable factors here to help you:
- Since this is flare piping, the design process pressure is relatively low;
- Since this is big bore piping, this facilitates the use of mitered elbows. This means that you might be justified in locally fabricating the mitered elbows.
Nevertheless, if you find that you can locally fab the elbows and justify their use, always apply Fallah’s excellent recommendation: never go forth with such an installation without doing serious and documented piping stress analysis and careful welding procedures and inspections.
Good luck.
Posted 22 March 2014 - 04:01 PM
Maximum Velocity For Piping In Fire Water Distribution System (Fire WaStarted by Guest_applepe_* , 06 Sep 2024 |
![]() Fire Case Gas Expansion (Gas Filled & No Liquid)Started by Guest_moosa.akbar_* , 27 Aug 2024 |
Pressure Drop In PipingStarted by Guest_Jaldhipatel_* , 05 Jun 2022 |
![]() Pressure Loss In Piping - Cooling Tower-Shelltube HeatexchangerStarted by Guest_Alneto_* , 29 May 2024 |
Piping Design_ Pump PipelineStarted by Guest_anh.phungthai@boydensvn_* , 29 Feb 2024 |
