Hi Guys,
I have sonic velocity of nitrogen gas calculated. Can I use this Vs in the continuity equation(Q=VA) to calculate flow rate or if there is some other criteria finding flow rate for isentropic flow?
Posted 13 March 2014 - 08:05 AM
Hi Guys,
Posted 13 March 2014 - 10:25 AM
That should work. Check your result with orifice sizing calculations.
Posted 13 March 2014 - 12:06 PM
![]() Recommended Fluid VelocityStarted by Guest_crn_* , 16 Apr 2025 |
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
![]() Colebrook's Equation - Friction FactorStarted by Guest_breizh_* , 10 Nov 2024 |
C Factor For Erosional Velocity For Multi-Phase Flow (Nat Gas/ ProduceStarted by Guest_Sam11_* , 10 Sep 2024 |
