Colour Change Of Some Hydrocarbons.
Posted 05 April 2014 - 01:32 AM
Posted 05 April 2014 - 01:40 AM
please give me answer to my question ?
hey guys its a my observation (exactly i dont know time to colour change but iam sure to say that the sample is colour changed with UV rays.)
Posted 08 September 2014 - 06:34 AM
One of the reasons for color change of distilled petroleum products on exposure to light is the presence of basic nitrogen.
Posted 23 September 2014 - 12:30 AM
Hello Everyone,
I have a small coconut oil extraction unit. Extracted oil is of slight yellow colour and a bad odour. I want some input on how to improve colour and odour of extracted oil.
Posted 23 September 2014 - 05:30 AM
Please give more details. Are you extracting with a solvent? Or by applying hydraulic pressure? IF you are extracting with some solvent, the odor may be due to residual solvent present in the oil. Color may also be due to residual solvent if the solvent is colored or due to the presence of inherent colored materiaUse a volatile sovent like Food Grade Hexane having Saybolt color of +30.ls. If you are expelling the oil from coconuts by applying pressure, the color mostly is due to inherent (presene of colored material). Activated charcoal is useful for removing colors and odors.
Posted 06 October 2014 - 01:08 AM
Dear Sir,
Thank You for replying, yes i'm extracting oil by applying pressure. Raw material supplier is spraying sulphur on coconut for preservation which i think is imparting yellow colour to the oil. Can this be removed by activated charcoal?
Posted 07 October 2014 - 10:09 PM
If elemental sulfur is used for prservation and contaminating the coconut oil, you can check by UOP 286 Mercury Number Test. You can adapt this for coconut oil also although it is meant for liquid hydrocarbons. If you find that the ol is viscous, dilute it with n-decane (sulfur free). If any black film forms on mercury, it is due to free sulfur You may try using oleic acid also
If the color is due to free sulfur, to my knowledge, only stopping the use of free sulfur would be a remedy . . Write to me if you need any further help.
![]() ![]() How Does A Vsd Gas Centrifugal Compressor React To A Demand ChangeStarted by Guest_AlexNguyen_* , 08 Jun 2023 |
Change Of State Inside The Lng Heat Exchanger HysysStarted by Guest_Luna D_* , 15 Mar 2023 |
How To Change Saturated Steam In Dry Steam In Heat ExchangerStarted by Guest_Orzelgorskiego_* , 13 Nov 2022 |
Flow Change With Delta PStarted by Guest_james.corrobro@gmail.com_* , 15 Aug 2022 |
Pressure Change Of Air In A VesselStarted by Guest_panoska_* , 05 Mar 2022 |
