Hello all
I want to simulate a helium recovery plant using aspen hysys. However, I am a bit confused on which fluid package I should use. The recovery plant will have the following components: helium, nitrogen, methane, argon, oxygen, hydrogen, water, neon, carbon monoxide, carbon dioxide and lube oil. The pressure range from 1 bar to 30 bar in the process and the temperature range from (70 deg C) to (4 K). In the process we will have cryogenic liquids (liquid helium as well). So which fluid package is most suitable ?
Thanks,
