Software Available For Flare Evaluation
flare software
#1 hugol
hugol
  • 6 posts
Posted 29 May 2014 - 09:29 AM
Dear All:
Can someone help me identify what type of software is available for flare evaluation? (Hydraulics, radiation, etc)
I´ve worked with SIMSCI Visual Flow but would like to explore other alternatives.
Thanks for your kind support on this matter
Hugo
#2 flarenuf
flarenuf
  • 104 posts
Posted 29 May 2014 - 10:10 AM
hello Hugo
short list of most used commercially available software packages
HYDRAULICS  : steady state   Aspen Flare System analyser ( Flarenet) will both rate and design a new system for you .
                                                Unisim Flare ( virtually the same, ), Aspen Plus, Chemcad Safety, VMG
                          dynamic         Aspen Hysys and Unisim Design , VMG,
RaDIATION & Dispersion         FLARESIM, Phast,
There are several other packages that do "bits" of the design /rating but the ones above are the most widely used in the industry
No doubt other users will add one or two i have missed out .
flarenuf
#3 hugol
hugol
  • 6 posts
Posted 29 May 2014 - 03:45 PM
Dear flarenuf.
Thanks a lot for your help on this matter.
I´ll wait to see if any other software comes into the table.
Best regards
Hugo
hello Hugo
flarenuf
#4 Robert Montoya
Robert Montoya
  • 170 posts
Posted 29 May 2014 - 04:09 PM
Hi also INPLANT you can use...
#5 PaoloPemi
PaoloPemi
  • 550 posts
Posted 30 May 2014 - 01:30 AM
there are many alternatives depending from the problem you need to solve,
hydraulics
a1) without change of phase, for example gas to flare, a software capable to evaluate pressure drop (and critical flow condition) can do the work (perhaps you already own one).
a2) with change of phase, you need a software with VLE and rigorous evaluation of critical condition, a simulator (as SIMSCI or those mentioned by Flarenuf) or a process library can do the work (I use Prode Properties which includes rigorous methods for  single and multiphase flow / critical conditions).
Radiation, design
b1) quick evaluation of thermal radiation, noise levels, design according APi 521, ISO etc. there are many (free) resources as Excel pages available, google can help.
b2) complete and integrated evaluation including design, isopleths etc. see the products mentioned by Flarenuf (there are many others but selection would require additional data about your applications)
#6 opel
opel
  • 23 posts
Posted 13 February 2015 - 01:26 PM
FLARETOT can also be used, offers wide range of calculation options.
