Filter Separator For Natural Gas
filter separator velocity liquid reservoir
#1 sukanta87
sukanta87
  • 90 posts
Posted 02 June 2014 - 05:57 AM
Would anyone suggest what should be or usual maximum allowable velocity through the filter cartridges?
In some cases the dimension of liquid reservoir become larger than filter vessel to fulfill a required volume. Does that looks good?
Edited by sukanta87, 02 June 2014 - 05:59 AM.
#2 sebaversa
sebaversa
Posted 12 June 2014 - 08:45 AM
Dear sukanta87.
I've an old chart for actual volume flow through cartridges (it would be the same as velocity), so you can properly predesign this equipment for a generic type of cartridge.
I can't attach the image, but you can build it with Excel as follows:
- X-axis is flowing pressure [psig]
- Y-axis is flow limit (capacity) [CFM/ft^2]
- The relationship is linear, and two points as follows:
  a) (600 psig; 30 CFM/ft^2)
  B) (1100 psig; 10 CFM/ft^2)
- Chart range: 0 - 1200 psig; 0-50 CFM/ft^2
That's all the information you need!
After that, you should be aware of provider's proposal because they ussually don't like to share design information for their cartridges.
Hope this helps,
Sebastián
#3 Propacket
Propacket
  • 260 posts
Posted 13 June 2014 - 02:54 AM
Refer to GPSA Chapter 7, use Souders Brown's equation with K Factor of 1.3 ft/s. It will give you approximate diameter of the filter.
#4 sukanta87
sukanta87
  • 90 posts
Posted 17 June 2014 - 01:01 AM
Thanks sebaversa and propacket.
Sebaversa, your methodology is useful and makes sense for preliminary design. Yes, provider's recommendation is specific.
Propacket, does this K factor useful for filter catridges? It seems enough higher. In GPSA, there are some values for mesh pad and vane type mist eliminator.
#5 sebaversa
sebaversa
Posted 22 June 2014 - 04:52 PM
Glad to help!
Good luck!
