Dear all,
I have a query regarding the sizing method for the rupture disc.
As per section 5.11 of API STD 520 Pt-1, when you have independent rupture disk, sizing can be by two different method:
1) Rupture Disk Sizing Using Coefficient of Discharge Method (Kd = 0.62)
2) Rupture Disk Sizing Using Flow Resistance Method
However for the discharge coefficient method can be used only if rupture disk discharges to atmosphere, is installed within 8 pipe diameters from the vessel nozzle entry, has a length of discharge not greater than 5 pipe diameters and has nominal diamters of the inlet and outlet discharge piping equal to or greater than nominal pipe size of the device.
In my current project, none of the above condition is satisfied, still vendor (REMBE) is using the Discharge Coefficient method. As per vendor, none of the supplier in the market use Flow Resistance Method to size the Rupture disk. I have requested to provide KR factor (for resistance method) and try to validate the size selected and found that the size of the orifice which supplier was offering with Discharge coefficient method is actually smaller than required based on Flow Resistance Method.
Can anybody share their experience regarding the above discrepancies and way forward.
Thanks and Regards,
Gunjan
