Heat Capacity Equation Integration
#1 Said Salim
Said Salim
  • 98 posts
Posted 12 June 2014 - 06:27 AM
I am calculating the change of the enthalpy of a system using this equation:
dH= ∫ Cp dT.
However, I am using fomula used Perry's to calculate Cp of ideal gas but I need the integral of this equation:
cp=c1+c2*(c3/t/(sinh(c3/t))^2+c4(c5/t/cosh(c5/t))^2
where,
c1, c2, c3, c4 & c5 are constants and t is the temperature in K
anyone can help to find the integral form
Edited by Said Salim, 12 June 2014 - 06:29 AM.
  • 6,715 posts
Posted 12 June 2014 - 07:29 AM
Said .
thanks to share the reference ( Perry edition &page)  and product name !
I would expect a polynomial .
Edited by breizh, 12 June 2014 - 07:31 AM.
#3 MrShorty
MrShorty
  • 517 posts
Posted 12 June 2014 - 09:17 AM
This equation is often called the Ally and Lee equation: http://www.trc.nist....0/AlyLeeCp0.htm
I expect you should be able to get a hold of Ally and Lee's original publication (http://www.sciencedi...378381281850029) and see how they derived the equation for H.
With an integral table and your own skill at deriving antiderivatives, you should be able to come up with your own formula. http://en.wikipedia....bolic_functions
#4 Said Salim
Said Salim
  • 98 posts
Posted 15 June 2014 - 10:54 PM
Hello Dear Sir,
The reference is Perry 7th Edition Page (2-182)
#5 PingPong
PingPong
  • 1,466 posts
Posted 16 June 2014 - 04:31 AM
The number of brackets in your equation is not correct, the bracket just before sinh should not be there.
It should be: c1+c2*(c3/x/sinh(c3/x))^2+c4(c5/x/cosh(c5/x))^2
in which I also replaced t by x to allow integration by website software.
Copy/paste that corrected formula into the window of the Wolfram website (overwrite example that is already there) and press the blue button:
Attached File  Cp Integration.jpg   64.43KB   10 downloads
http://integrals.wolfram.com/index.jsp
Edited by PingPong, 16 June 2014 - 04:43 AM.
#6 Said Salim
Said Salim
  • 98 posts
Posted 16 June 2014 - 06:15 AM
Thanx alot Sir.
I appreciate you response..
