Has anybody done any calculations before for a heat transfer from ambient air to a liquid inside the storage tank? let me explain the situation:
I have a horizontal vessel of capacity 12.5ft I.D X 40ft length with 5ft of liquid level.
The liquid inside the vessel is about 98% propane and 1.5% ethane and 0.5% butane+ (The composition is mol%).
The pressure inside the vessel is 1.4 psig and the temperature is -45 F. (The liquids are at its bubble point)
I have 3.5" of polyurethane insulation around the vessel.
The design temperature of the vessel is -50 F(Low temperature carbon steel) and the design pressure is 300 psig.
The ambient air is at 100 F and the wind velocity is 20 ft/sec. The heat should transfer through the insulation layer and then through the vessel wall to the liquid inside the vessel. Increase in temperature of liquids inside the tank will raise the pressure. we also have to remember that the vaporization of liquid also bring the liquid level down.
I want to know the pressure and temperature profiles inside the tank for every one hour until it comes to a point where the ambient temperature no longer heat the liquids inside the tank.
I appreciate your help.
Thanks.
