Steam Tracing
#1 farid.k
farid.k
  • 384 posts
Posted 22 June 2014 - 12:39 AM
hye all.
I am totally blind regarding to the steam tracing. I have a project to solve an icing problem at piping. The proposed solution is to install steam tracing. My question is:
1.  What is the method of calculating steam tracing loads? Or is it by vendor (client just give temperature or info only)?
2. What if the piping that need steam tracing is very long i.e. 100 meter? Does it have to be steam tracing need to supply for every 10 meters?
3. How to know the condensate recovery system? I mean how to know that must go to the condensate recovery header or just to open drain system?
thank you
  • 6,715 posts
Posted 22 June 2014 - 03:00 AM
farid ,
Probably good to use the search  engine in this forum . Anyway I 've attached a link where you should find good info about tracing and tools for design .
http://www.thermon.c...in/default.aspx
Another resource :
https://www.google.f... tracing design
Hope this helps
Edited by breizh, 22 June 2014 - 04:08 AM.
#3 Art Montemayor
Posted 23 June 2014 - 09:08 AM
Farid:
Breizh has given some good leads – especially the Thermon one.  However, his lead doesn’t take you to the real source of all the Thermon design data and information.  That URL is: http://www.thermon.c...eamtracing.aspx
At this site you will find all the necessary and important information on designing and installing a successful steam tracing system.  The basic secret of the Thermon design is the employment of their very successful thermal cement – which efficiently conducts the required heat transfer from the steam tubing to the target pipe wall.
I have used Thermon on many steam tracing applications and always had success.  Note that they give you free design software that you can readily apply.  I never “wrap” the steam tubing around the target pipe, but rather run a parallel tube (I favor 3/8”OD) on top or bottom of the pipe strapped and cemented.  I attach a sample picture of a typical installation.
#4 Bobby Strain
Posted 23 June 2014 - 11:29 AM
How about electric tracing?
#5 farid.k
farid.k
  • 384 posts
Posted 23 June 2014 - 10:12 PM
 For me, it is good also to use electric tracing. Easy to control and installation not complicated as steam tracing (take from steam manifold, go back to condensate manifold, steam trap etc2). Just that they want to utilise the available steam at site plus there is nearby steam tracing manifold. I already communicate with THERMON representative in my country, they said, they is more to electrical tracing. However they can help on this matter for steam tracing.
Farid:
Thank you for the link. It really helps me in term of understanding the heat tracing philosophy. Already communicate with them. However, they are more to electrical tracing. I do prefer to use electrical tracing as it is easier to control and installation is less complex compared to steam. But I don’t really know in term of equipment cost, installation cost and operating cost which one is more economical. Based on client request, they preferred to use steam tracing as in plant practise mostly use steam. Actually, the need of the heat tracing is from piping icing problem. There is one piping suffer icing problem and caused the piping cant flow normally. Currently they just use steam from utility station to fix the problem.
farid ,
Another resource :
Hope this helps
thanks for the link. it really helpfull=)
#6 breizh
  • 6,715 posts
Posted 24 June 2014 - 06:49 PM
Farid ,
On operation view point it's better to use electrical tracing , especially if you have to dismantle the piping to clear the line , less risk to damage and easier to install back . Copper pipe is quite fragile !!
My experience.
Edited by breizh, 24 June 2014 - 06:52 PM.
#7 oscarsender
oscarsender
  • 39 posts
Posted 24 June 2014 - 07:18 PM
As much as possible we don't want to open drain the condensate since it was already treated unless it was contaminated along the line. With this we can save a certain amount of boiler feed water which needs to undergo series of treatments before being fed to the boiler.
