Aspen Plus - Base Method / Property Method Selection Problem
aspen plus
7 replies to this topic
#1 Nelson John
Nelson John
Posted 24 June 2014 - 01:19 AM
For all those who faced the problem of selecting a base method under the property specifications tab (Data browser) in any of Aspen plus versions. (Found a user unable to select any of the methods from the drop down list) -- Solution: In case you are not able to make any selections (only then) -- Just checkmark the box " Modify property models" , enter any id, specify the below details under the modify property models. Now you will be able to select any BASE METHOD & PROPERTY METHOD of your choice. Hope this solution helps.
Edited by Nelson John, 24 June 2014 - 01:26 AM.
#2 ardalan4209
ardalan4209
  • 10 posts
Posted 18 October 2014 - 09:33 AM
I Have faced severe problem in modeling natural gas burner, aspen gives me an error like this:
PHYSICAL PROPERTY PARAMETER DGFORM   OR DGAQFM   IS MISSING FOR COMPONENT BELOW: AIR
I dont know what should I do to solve this problem, plz help
#3 PingPong
PingPong
  • 1,466 posts
Posted 18 October 2014 - 09:42 AM
Air is a mixture of several components, mainly nitrogen and oxygen.
Simply replace Air by a stream of 79 mol% N2 and 21 mol% O2
#4 ardalan4209
ardalan4209
  • 10 posts
Posted 18 October 2014 - 10:42 AM
Tank you for your hint, it worked, I have another question and I really appreciate if you help
Which base property method is more suitable for modeling with streams like air, natural gas and steam? I have faced dilemma between using PNG ROBINSON or IDEAL?
Sincerely
#5 PingPong
PingPong
  • 1,466 posts
Posted 18 October 2014 - 11:18 AM
Use Peng Robinson.
#6 ardalan4209
ardalan4209
  • 10 posts
Posted 19 October 2014 - 02:11 AM
Hi PingPong
Do you know what is the difference between polytropic compressor by using ASME method and polytropic compressor by using piecewise integration? I think the former uses ASME codes to design and is more accurate than the latter.
#7 PingPong
PingPong
  • 1,466 posts
Posted 19 October 2014 - 05:28 AM
ASME method is well known in the industry and is based on ASME Performance Test Code 10 (PTC 10-1997) which uses inlet and outlet conditions of compressor and applies a correction factor to calculate Work and Head.
I don't use Aspen, so I don't know the details of their "piecewise integration" method, but I expect that it divides the compression in a lot of small steps from inlet to outlet. You should check the Aspen manual for details.
Edited by PingPong, 19 October 2014 - 05:28 AM.
#8 ardalan4209
ardalan4209
  • 10 posts
Posted 19 October 2014 - 01:12 PM
woooww your information is complete and totally professional, really thank you
