Hi all,
I just want to ask if anybody know, how to find heat transfer coefficient of water in a pipe/tank at resting condition or flowing.
Thanks for any help!!
Posted 10 July 2014 - 12:11 AM
Hi all,
Posted 10 July 2014 - 04:11 AM
Note that the overall heat transfer coefficient U not only depends on the partial heat transfer coefficient from water to wall, but also on heat resistance of wall, and partial heat transfer coefficient of wall to the medium on other side. If present, the heat resistance of any insulation also has a huge impact on value of U.
You have to define your problem in much more detail than just one sentence.
Posted 10 July 2014 - 08:56 PM
PingPong,
I'm calculating heat transfer in a 10" OD PVC-pipe (k = 0.19 W/m.K, t = 15 mm, l = 3 m) with 500 m^3/hr water (40 deg C) flowing through the pipe (35 deg C ambient temperature). I'm thinking to calculate it by either forced convection or steady state loss (thermal circuit concept). For steady state loss, I need the heat transfer coefficient from the fluid to the inner wall and from outer wall to ambient. I found a website that provide heat transfer coefficient for water, but it doesn't seem to be clear, because it only gives the range value and doesn't specify for the temperature, condition, etc. What I am trying to do is to find the heat transfer coefficient (h) of water based on condition, properties given.
Anyone could help with this?
Thanks!!
Posted 11 July 2014 - 03:50 AM
Every book on Heat Transfer gives formulas to calculate h for flowing fluids inside pipes.
h for flowing water inside a pipe will be very high, in the order of 1000 or more W/m2.K.
What matters however is not h but the overall heat transfer coefficient U, which in your case will be mainly determined by the PVC pipewall and the transfer of heat from the outer wall to the ambient air by natural convection (if no wind) and radiation. That U will be very small, I suspect in the order of 5 - 10 W/m2.K (depending on wind speed). If there is a lot of sun radiation it gets more complicated and the pipe may even gain heat during parts of the day instead of lose heat.
As the length of your pipe is only 3 meters, I wonder why you would want to go through the trouble of trying to calculate a tiny heat loss (or gain), also in view of the fact that you seem to have no knowledge on the subject.
Anyway: if you like, you can learn about the subject by reading a book on Heat Transfer, like the one you can freely download from the MIT website: http://web.mit.edu/l...load-ahtt.shtml
Edited by PingPong, 11 July 2014 - 04:06 AM.
Posted 15 July 2014 - 01:17 AM
PingPong,
What about the fluid is resting? How to find h, when the fluid is resting. Because based on my calculation that I've done using internal forced convection, the thermal resistance from PVC is quite dominant, so that it holds the heat transfer to outside pipe.
What is actually the difference between overall heat transfer coefficient, U and heat transfer coefficient, h? Isn't is the same? U is just the result of 1/sum of h, right? At the end of the day, we have to find h first, in order to get U, am I right? What I don't know is how to get h of water when water is resting in a pipe/tank based on type the conditions applied in the system (such as, flow properties, fluid properties, temperature gradient). Is there such way to calculate h as I wanted?
That's right, I don't have knowledge of this, that's why I find for help here.
Thanks!!
Posted 15 July 2014 - 07:01 AM
U is not the same as h.
If, for simplicity, we assume that the pipe inner surface Ai is equal to its outer surface Ao then the formula for U simplifies to:
U = 1 / ( 1/hi + x/k + 1/ho )
in which
hi = heat transfer coefficient (filmcoefficient) for medium inside tube to tubewall, W/m2.K
ho = heat transfer coefficient (filmcoefficient) for medium outside tube to tubewall, W/m2.K
x = thickness of tube wall = 0.015 m
k = thermal conductivity of tubewall = 0.19 W/m.K for PVC
hi for streaming water is > 1000 W/m2.K, for resting water it is > 100 W/m2.K
ho for resting ambient air is in the order of 5 to 10 W/m2.K including radiation heat loss
This gives a U = ~ 5 W/m2.K irrespective whether the water is streaming or resting. If there is wind U may be about 10 W/m2.K
It should be obvious from the U formula that even if the water streams very fast and the wind is a storm the value of U can never be higher than 13 W/m2.K due to the heat resistance of the PVC pipe wall (0.19 W/m.K / 0.015 m = 13 W/m2.K).
The above values for hi and ho come out of my (experienced) thumb. You can try to calculate them more accurately using the formulas in the MIT book that I mentioned before, but the result will be roughly the same:
- the water streaming velocity has no impact on U because its h is always very many times higher than 13 W/m2.K
- the expected value of U is in the order of 5 - 10 W/m2.K depending on the wind speed.
Posted 15 July 2014 - 11:40 PM
PingPong,
Thanks for your response, it's very helpful.
So, for hi and ho, we just assume roughly? This is actually what I want to know, if there is such way to calculate these coefficients based on conditions applied?
Ok, I think, I understand a bit about this. If let say, we have case 1 which is the same with what you have made, but with high air velocity, say 10 m/s. Will that help?
Or case 2, let say we have good material pipe, but with low air velocity, say 2 m/s. Will this be much better?
Again, thank you!!
Posted 16 July 2014 - 03:43 AM
So, for hi and ho, we just assume roughly? This is actually what I want to know, if there is such way to calculate these coefficients based on conditions applied?We do not assume something, only I assume something because I know from experience what hi and ho will roughly be, and that in this case with a PVC pipe wall the value of hi and ho hardly matter.
Air velocity will have impact on ho and therefor some impact on U.
You can calculate impact of air velocity with the formulas for natural convection and forced convection from the MIT book. Give it a try.
Water velocity has an impact on hi but that has absolutely no impact on U in this case with PVC pipe because 1/hi is very very small compared to x/k and 1/ho
Also in case of a steel pipe water velocity will have hardly any impact on U, as U will then be determined mainly by the fairly low ho of the air.
Heat transfer is not an easy subject. It is often underestimated by young engineers. If you want to learn you have to do effort and study.
Posted 16 July 2014 - 11:22 PM
PingPong,
This is getting complicated. I tried to find natural convection and external forced convection of the pipe, but then both of them need Ts of the pipe which is outside wall temperature of the pipe. How actually to find this?
I tried to use steady heat loss, to find the surface temperature, but then again the same problem appeared. To get the total resistance, we need to have Ri = 1/hi Ai (where hi is fluid heat transfer coefficient), I got stuck finding this hi. I have been referring to yunus cengel textbook, but in that book, there is no formula to calculate that hi, instead it only has some range of typical values of heat transfer coefficient for gases and liquids. Is it possible to use that?
Or my method of finding this surface temperature is not right? If it's right, the only problem is to find the hi.
You are right, heat transfer is never easy.
Posted 17 July 2014 - 04:09 AM
Tso (and Tsi) can only be found by trial-and-error:
Assume a value for Tso of say 37 oC (and Tsi of say 39.5 oC), calculate Ri = 1/hi and Rw = x/k and Ro = 1/ho
Temperature profile from Ti via Tsi and Tso to To follows profile of R's as you can find in any heat transfer book.
That gives you new value for Tso (and Tsi). And based on those you calculate again Ro and Ri
et cetera.
I am sure there are formulas for hi in that book. Look again.
They are also in the MIT book that I mentioned before.
Edited by PingPong, 17 July 2014 - 08:44 AM.
Posted 20 July 2014 - 11:37 PM
Why it can only be found by trial and error? I think if we can get all resistance in the pipe and know Ti and Tambient, we can get Tsi and Tso , by using steady heat loss/thermal circuit concept, is that right?
Can you just let me know, what chapter should I read to know how to calculate hi? Because I have been trying to find it, but I couldn't find it, in most examples of chapter 3 in Yunus Cengel textbook, it always has value of hi, therefore, they don't calculate hi.
Posted 21 July 2014 - 03:19 AM
Why it can only be found by trial and error?For natural convection of water and ambient air Tsi and Tso can only be found by trial and error, because hi and ho are a function of Tsi and Tso
In case of forced convection of water and air no trial-and-error is required.
Cengel chapter 9 is about natural convection to calculate hi and ho
Cengel chapter 8 is about forced convection.inside tubes to calculate hi
Cengel chapter 7 is about forced convection.outside tubes to calculate ho
Posted 22 July 2014 - 12:06 AM
But I think if we use steady heat loss, we can get each temperature on pipe's wall, is this right? Tsi is inner wall temperature and Tso outer wall temperature, right?
I am looking formula to find hi when water inside pipe is resting. This chapter, I think for flowing water inside the pipe.
Posted 22 July 2014 - 02:18 AM
But I think if we use steady heat loss, we can get each temperature on pipe's wall, is this right?No, not for natural convection in resting fluids.
Tsi is inner wall temperature and Tso outer wall temperature, right?Yes.
Posted 23 July 2014 - 09:08 PM
Quote
I don't get what you mean here.
I don't know why you said there is where I couldn't find how to calculate hi.
