Deepak93:
Heater-Treater design has traditionally been concentrated in the area of special oil & gas engineering and fabricators. This is a very specialized and arcane part of our industry that has developed through the years based on empirical data and experience-based expertise. Please read some of the attached documents to get an idea of where the real experience in this field rests.
As I previously advised you, you should furnish ALL of the detailed information and basic data that you have on your topic. The more information you furnish the more help we can give. Include a detailed flow diagram of your proposed process as well with temperatures, pressures, and compositions. For example, how much background and basic information do you know about heater-treaters? Are you proposing to heat your treater with a direct-fired firetube? What type of crude are you using? At what pressure? We can only help you as much as you help us. You could also do extensive internet research - where most of this material came from.
I strongly recommend you heed the above if you want or need detailed help on specific details. For example, if you plan to use a fire tube, I would recommend you use a conservative heat flux. These type of heaters are designed using a heat flux, based on prior experience.
I hope this helps.
About Heater Treaters.doc 32.5KB
55 downloads
BS&B Horizontal Treaters.pdf 328.85KB
71 downloads
Crude Oil Treaters.docx 16.5KB
55 downloads
Field Production Heater-Treaters.docx 142.51KB
46 downloads
Horizontal Heater Treater Drawing.pdf 54.02KB
65 downloads
Horizontal Heater Treater.doc 500KB
43 downloads
Natco Heater-Treater.doc 654KB
42 downloads
Permian Tank Heater Treaters.docx 109.56KB
32 downloads
Petreco Heater-Treater.docx 19.08KB
46 downloads
