Does anyone have access to a graph that compares concentration of HCl (wt%) to vapor pressure at given temperatures?
Posted 17 July 2014 - 11:28 AM
Posted 17 July 2014 - 11:37 AM
Wikipedia has some data (if you trust them): http://en.wikipedia....drochloric_acid
Perry's had some data, too, if I remember correctly.
I expect if you put "HCl water pressure data" or similar into your favorite internet search engine, you would find references to other sources.
Posted 17 July 2014 - 06:50 PM
additional info .
Hope this helps
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
