Hcl Packed Bed Scrubber Design
packed bed scrubber
7 replies to this topic
#1 Rajesh Patel
Rajesh Patel
  • 8 posts
Posted 28 July 2014 - 04:34 AM
Hi
I have an action to determine capacity of existing scrubber used to scrub pure (100%) HCL gas.
How to apply NTU = LN ( Ybottom/ Ytop ) equation for 100% HCL gas input and 2ppm HCL concentration in outlet?
Can you recommend equation for HTU also for same condition?
Rajesh Patel
  • 6,714 posts
Posted 28 July 2014 - 06:20 AM
Rajesh,
Consider this resource.
Hope this helps
#3 Art Montemayor
Posted 28 July 2014 - 09:32 AM
Pierre:
What happened to your handsome photo?  It was much better than the present one.
#4 breizh
  • 6,714 posts
Posted 28 July 2014 - 06:26 PM
Art ,
I tried to upload  a "fresh one" and failed !
Have a good day .
Pierre
#5 Art Montemayor
Posted 28 July 2014 - 09:13 PM
Pierre:
Ah!  That's a lot better.
I thought for a moment that some viral attack had taken place on our member's photos.
Thanks.
#6 Rajesh Patel
Rajesh Patel
  • 8 posts
Posted 29 July 2014 - 04:29 AM
In ref of my question as above:
Inlet is pure HCL gas and density is 1.4 kg/m3.
Outlet should not increase HCL concentration more than 2PPM.
Can I take following value of Ybottom and Ytop?
Ybottom = 1400 gm/m3
Ytop = 2PPM = 0.00.2982 gm/m3 (Converted PPM into gm/m3)
#7 Rajesh Patel
Rajesh Patel
  • 8 posts
Posted 30 July 2014 - 03:42 AM
Please note, Ytop =  0.002982 gm/m3
#8 siretb
siretb
    ChE Jedi
  • 304 posts
Posted 01 August 2014 - 04:38 AM
Hi
You want to scrub pure HCl?  When you say you want 2ppm at top, does this imply that that the rest is water vapor and some inerts (not present in the feed of pure HCl) to be scrubbed.
I think that 2ppm is not much, I would rather consider 5 but this is your specification
Scrubbing HCl with water will have a large heat (enthalpy) effect, and shortcut designs (like the ones involving HTU-NTU) are not safe when you deal with concentrated solutions, which seems the case.
You should calculate the first stages using rigorous methods (you need to make a choice on how concentrated you want the acid to be at bottom, that will yield the liquid rate, and the temperature.
for the final stages (top) the HTU will be packing dependant    Count HTU between 0.2 and 0.4 meters.
keep in mind hot HCl is highly corrosive
