Evaporation Rate As Per Api 2000
#1 Nagarajan K
Nagarajan K
  • 31 posts
Posted 13 August 2014 - 01:10 AM
I am bit confused with Evaporation rate calculation method mentioned in API 2000.
As per Clause, In Annex-A, A.3.2.3, 2nd last Paragraph.
What Exactly does it says,
I carried out calculation as follows.
My incoming flow rate is 112 m3/hr at 45 deg C.
Density of Liquid is 985 kg/me at 45 Deg C.
So may Mass flow is 110320 kg/hr.
Evaporation rate of 0.5 %, So evaporation mass flow rate is  0.005 * 110320 = 551.6 kg/hr.
Next say Density of Air is 1.29 kg/m3 at 45 deg C.
(As per 2nd last statement of 2nd last paragraph).
HC vapor density is 1.5 times of Air Density = 1.5 * 1.29 = 1.935 kg/m3
So my evaporation rate is 551.6/1.935 kg/m3
Evaporation rate = 285.06 m3/hr @ 45 deg C.
Evaporation rate in Nm3/hr is = 245 nm3/hr.
Am i Correct .
I have a Doubt.
Nagarajan K
  • 6,715 posts
Posted 13 August 2014 - 01:16 AM
You need to define the meaning of Nm3 . It's not at 45 C and then you perform adjustment based on your reference ( 0C or 60F or ??)  using the general equation : P1*V1/T1 =P2*V2/T2.
Hope this helps
Edited by breizh, 13 August 2014 - 01:19 AM.
#3 Nagarajan K
Nagarajan K
  • 31 posts
Posted 13 August 2014 - 01:44 AM
Dear Breizh,
The approx flow rate calculated for 245 Nm3/hr from actual flow rate of 285.06 Nm3/hr using P1V1/T1=P2V2/T2.
Nagarajan K
#4 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 13 August 2014 - 01:49 AM
Nagarajan,
Refer the link below ans specifically post #28  by latexman.
http://www.cheresour...ervative/page-2
#5 Nagarajan K
Nagarajan K
  • 31 posts
Posted 13 August 2014 - 02:40 AM
I followed d same conversion but,is the method correct to find out Evaporation rate?
Nagarajan K
