Pathfinder:
It's taken some time to answer each one of your numerous questions. I've added my reply to each in RED, below:
1. The inlet separator before the contactor (Absorber) is installed as a slug catcher and hence to prevent foaming?
The purpose of the inlet separator is to remove any contaminants from the humid feed natural gas going to the TEG Contactor. The role that this separator plays is one of the most important ones in the TEG process because it ensures that process upsets such as foaming, fouling, and TEG contamination will be mitigated. The proper sizing and efficient operation of this piece of equipment cannot be overstressed.
2. What are the major causes of foaming. Where else can it occur other than in the contactor?
The major cause of foaming in a TEG process is oil or heavy hydrocarbons carried into the process by the feed gas or by greases introduced elsewhere in the process.
TEG does not foam by itself. Any contaminant that affects TEG surface tension will cause foaming. The most common cause of glycol carryover from the contactor is mass-transfer-induced foaming. Elevated or fluctuating contactor differential pressures are indicators of foaming with related glycol losses. Gas entering the contactor must be free of all liquid and fine solid particles to avoid contactor contamination and foaming. Carryover of hydrocarbon condensate due to scrubber mist eliminator malfunction or high gas velocity in the contactor causes foaming. Also, TEG inlet temperature to the contactor should be 10 oF higher than the gas outlet to avoid liquid hydrocarbon condensation. A flash tank residence time of at least 5 minutes is needed to separate lighter hydrocarbons from rich TEG. Foaming inducers should be removed by the sock filter and activated carbon filter. Particles of 5 microns and larger should be removed by the sock filter. The activated carbon filter removes organic products like acids and traces of liquid hydrocarbons. An iron content of 15 ppm or higher in the TEG will increase foaming.
3. As seen in many PFDs, is the outlet (dry) gas pass through a TEG cooler before connecting to the supply line? If so what should be the ideal temp/pressure for this gas? OR is it a heat exchanger where the lean glycol is cooled before it enters the contactor?
This question is written in bad English and is hard to understand. If you mean: “is a TEG cooler using product dry gas a requirement?”…. then the answer is no. Normally, product dry gas is used to cool the warm lean TEG entering the contactor. However, you can use any other coolant for this purpose – cooling water or atmospheric air.
4. According the PFD I have attached herewith, the dry gas passes through a “gas scrubber”. What are the advantages of this system?
This is not an “advantage”, but rather a necessity to remove any TEG particles exiting the contactor overheads entrained in the product dry gas. This is to reduce TEG losses and also avoid product gas contamination downstream.
5. Why is the rich glycol made to pass through the Reflux Condenser before entering the flash vessel?
The rich TEG is being used as a heat sink to cool and condense some of the water vapor rising in the still and also pre-heat itself at the same time.
6. As per Mr. Art's PFD, the rich glycol is again passed through a heat exchanger before reaching the flash vessel, why is that so? What’s the advantage and what is the ideal temperature of the liquid during these stages?
There is a need to heat the rich TEG and also to cool the lean TEG. The TEG exchanger is doing a portion of this need. It also reduces the fuel gas energy input into the reboiler.
7. What is happening in the still column after flashing? Why can’t it be directly fed to the reboiler?
The still column strips out the bulk of the water content in the rich TEG. You need approximately 1 ideal stage of separation for this to occur – that why you can’t just dump it into the reboiler.
8. What is stripping column for? What is stripped here and how does it happen?
In the reboiler the TEG is heated to approximately 400 oF to remove enough water vapor to re-concentrate it to 98.8 percent. However, Low dew points simply cannot be achieved using the maximum 98.8 wt % glycol obtainable with a 400 oF reboiler at atmospheric pressure. These low dew points will need up to 99.9 wt % lean glycol at the absorber top inlet. Increasing reboiler temperature is not an option due to the thermal decomposition temperature of 404 oF for TEG. Stripping gas has a much greater effect than increasing reboiler temperature. For maximum efficiency, stripping gas should be introduced in a short column after the hot glycol is removed from the reboiler.
9. As per the PFD I have attached, a “stripping gas” is provided to the surge drum. I understand the surge drum is a “surge” drum in its literal meaning.so can u explain this design we have? Especially the dry gas fed to the drum.
I don’t agree with the design shown in your PFD. If you refer to my PFD sketch, you will see what I advocate. Dry stripping gas should be introduced in the bottom of a packed bed that is contacting the lean, hot TEG exiting the reboiler and going to the Surge Drum.
10. The logic of glycol exchanger (E-XXX2).
There is no “logic” here. There is a specific duty requirement. Read the response to #6.
11. The flare line, it opens through a PSV whenever a back pressure from main line happens and also during shutdown time ... correct me if I’m wrong. A bit more idea abt flare will be helpful.
You PFD is not specific, so it is hard to explain exactly what the flare is handling in your design scheme. We need specific information.
12. For this project we have, we’re taking the TEG units as a whole from the vendor. So kindly advice any particular and important things (technical) to be reviewed before finalizing the vendor.
I don’t understand what you mean by “we’re taking the TEG units as a whole from the vendor”. We need to know what stage in the project you are in: have you already purchased the TEG unit or are you presently specifying or talking to vendors? This is important for us to know so we know what we can do something about and what we can’t do because the unit is already purchased. We need specific information as to where you are at in the project schedule and what we can help with in order to allow you avoid mistakes or errors.
You basically need to study the TEG process in depth. What you should already have read are such classic documents/books as:
- The GPSA Engineering Databook;
- “Gas Purification”, by Kohl and Nielson (1997);
- Gas Processing by John Campbell
- Glycol Dehydrator Design Manual – 1976 (which you can download for free right here in our website)
I am attaching some additional information for your reading as well.
Optimize TEG Circulation and Flash Tank.docx 571.75KB
189 downloads
Design Glycol Units for Maximum Efficiency.docx 128.04KB
183 downloads
