Need Of Balancing Line In Boiler Feed Pump
Posted 26 August 2014 - 04:56 AM
Posted 26 August 2014 - 06:15 AM
Hi Anil,
Balance leak off line is used to balance the centrifugal pump shaft from axial thrust. During pump operation, especially in multistage centrifugal, suction will have less pressure compared to discharge. Due to this, impeller along with the shaft will have a push from discharge end to suction end which is called as "axial thrust". Due to the axial thrust, pump bearings and internals will be affected. To nullify the axial thrust, a tapping from discharge end is connected to a balancing drum. The water coming out from balancing drum is routed in a line called as balance leak off line. Generally it is routed back to deaerator.
Hope this is clear!
#Samayaraj
Edited by samayaraj, 26 August 2014 - 06:23 AM.
Posted 26 August 2014 - 04:40 PM
Generally for vacuum services a balance line from pump to suction vessel is provided.
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
Inlet Line Not Free DrainingStarted by Guest_Asifdcet_* , 07 Apr 2025 |
Split The Feed Into Two Identical StreamsStarted by Guest_tomr91_* , 16 Mar 2025 |
