Relieving Capacity Versus Rated Capacity
9 replies to this topic
#1 Nagarajan K
Nagarajan K
  • 31 posts
Posted 26 September 2014 - 12:17 AM
Dear Sir,
I am really confused between rated and Relieving Capacity for safety valves.I tried in search engines.
got more confused.
I refereed API 520 and got formula to calculating relieving Capacity,but was confused with rated capacity and difference between them.
Kindly guide me.
Nagarajan K
#2 Sathya R
Sathya R
  • 35 posts
Posted 26 September 2014 - 05:01 AM
Reliving capacity is based on the scenario selected based process design. Rated capacity is higher and is based on the selected orifice.
#3 Nagarajan K
Nagarajan K
  • 31 posts
Posted 26 September 2014 - 05:46 AM
Dear Sathya,
so can rated and relieving can be same
#4 fallah
  • 5,019 posts
Posted 26 September 2014 - 06:33 AM
There are two relieving capacities for a PSV as follows:
Required relieving capacity: Has been obtained after credible scenarios analysis and governing scenario selection
Rated relieving capacity: Should be at least equal to required one and would be obtained by using actual ASME orifice size and actual ASME coefficient of discharge...It's same as PSV stamped capacity and is normally provided by PSV manufacturer...
#5 Nagarajan K
Nagarajan K
  • 31 posts
Posted 29 September 2014 - 04:04 AM
Thanks for your replies.
For
Do we consider Overpressure addition during calculating inlet pressure for PSV.
which in turn will be used to calculate Required relieving capacity,
NK
#6 fallah
  • 5,019 posts
Posted 29 September 2014 - 06:01 AM
To calculate required relieving capacity of a PSV, always upstream relieving pressure which is the summation of set pressure, allowable overpressure and atmospheric pressure, is to be considered...
#7 Rafael Espinoza
Rafael Espinoza
Posted 15 October 2014 - 12:59 PM
Well, I just want to use this tread because others (more appropriate to the subject) are closed,
The issue about relieve capacity, fire x blocked scenarios, chattering:
Going straight to the point: the rated capacity are always enough for the required capacity, but it's possible that the real scenario could develop much less relief flow than rated. (Partial fire exposure, for instance) In these cases chattering is possible. How to handle this chattering possibility?
#8 fallah
  • 5,019 posts
Posted 15 October 2014 - 01:38 PM
Rafael,
You can use modulating pilot operated PSV to avoid chattering...
#9 Bobby Strain
Posted 15 October 2014 - 02:11 PM
Nobody ever bothers to consider what is troubling you.
#10 Brocklesnar
Brocklesnar
  • 10 posts
Posted 21 October 2014 - 07:34 AM
Just to add to whats all said before,
Rated or nameplate capacity of any relief valve is stamped on the valve and matches the flow of compressible fluid (say steam) at saturated conditions of discharge. To obtain the relieving capacity at particular relieving point of set pressure and temperature, use the correction factors given in API-520 or ASME Section-I for superheat temperature, pressure > 1500 psi, type of PSV arrangement.
My experience tells that, for everything else remaining constant, the relieving capacity in superheated conditions is less than rated or nameplate capacity (which of course corresponds to saturated condition)
