we have stabilizer section in FCC gasoline desulfurization unit, from which the sour gas (contaning H2, H2s) is sent to DHDT unit for the offgas treatment with amine absorber and ultimately to fuel gas header. since we are using CCRU hydrogen for FCC gasoline desulfurization unit, the sour gas production is high and the stabilizer section is fully upset.sometimes the stabilizer overhead controller gets fully opened and the operating pressure (8.5kg/sq.cm) is difficult to maintain also the stabilizer column psv is at 11 kg/sq.cm. the stabilizer coulumn is stable when we are using PSA hydrogen. In stabilizer overhead we have one line(2") going to DHDT for offgas treatment and one line (2") going to flare.since the pressure in stabilizer is difficult to maintain with CCRU H2, flaring has to be done. how to avoid this flaring of sour gas?
now we have another section called isomerizatiion section, in this section the the stabilizer off gas contain (HCL, H2) which is being treated by NET GAS scrubber (by cautic 10 wt%) and is operating at max of 6.5-7kg/sq.cm. the off gas after treatment goes to fuel gas header.
can we route the sour gas to flare line from FCC gasoline desulfurization stabilizer section to NET GAS SCRUBBER? what will be the effects if i route the sour gas(H2&H2S) from fcc gasoline desulfurization unit to Net Gas Scrubber which is treating offgas (H2 & HCL) from isomerization unit and operating at 6-7kg/sq.cm ? basically i want to avoid flaring of sour gas from FCC gasoline desulfization unit, avoid using PSA hydrogen and make stabilizer section stable while using CCRU H2
