HI..
I have problem in my control valve, one of my control valve is having vibration since long time. In 1 pipe we have two phase liquid and gas, and the pressure of upstream is 420 KPa and the downstream is 140 Kpa. What is the problem of the control valve become shaking?
Devis
Vibration Of Control Valve
Started by Guest_phiez_*, Apr 17 2006 06:11 AM
Guest_phiez_*
Posted 17 April 2006 - 06:11 AM
Posted 17 April 2006 - 09:07 AM
You haven't provided many details (fluid composition, type of valve, valve size, operating temperature, flow rate, etc.). However, a liquid and gas mixture upstream of the valve will almost always cause vibration as gas bubbles (or liquid droplets, I don't know which one is the continuous phase) hit the valve, get accelerated, maybe grow and shrink again, as they pass through the valve. So if you can make the inlet single phase, this would help a lot. Otherwise, you'll need very good supports and a heavy duty valve trim to avoid problems.
Guest_phiez_*
Posted 17 April 2006 - 11:40 PM
Mr. Joe.
This urea solution + gas that contaion CO2, NH3 and inert, so where can i find the literature that i can calculate how much should be the right ca;cu;ation
thank
thank
Posted 18 April 2006 - 07:49 AM
Even though you still haven't supplied much, this looks like a difficult application (two-phase inlet). I suggest you consult the CV vendor for a good valve selection, read through the Fisher Control Valve Handbook at http://www.emersonpr...umentation.html and make sure that the valve is well supported to minimize vibration.
Posted 19 April 2006 - 08:26 AM
Have you checked for cavitation of the liquid?
Guest_Guest_ASH25320_*_*
Posted 15 July 2006 - 11:29 PM
May be U should try reversing the direction of the control valve, for in our case for the same urea service valve was giving vibration & abnormal sound(composition 85 % urea+co2+nh3).Since no spares were available upon consulting the vendor we reversed the direction of the valve, only to find that the problem is solved.
![]() Ditance Between Globe Valve And Ball ValveStarted by Guest_sima-f_* , 05 Jan 2025 |
