Can anyone tell me the philosophy, selecting the locaiton of corrosion coupon in oil and gas industry. In general, where we can avoid it in hydrocarbon service, I mean is there in guideline which can help to know further on this subject.
Corrosion Coupon Location
Started by Bhavinkumar, Nov 11 2014 12:40 AM
Posted 11 November 2014 - 12:40 AM
Posted 11 November 2014 - 07:27 AM
Install a corrosion coupon in the place where is predicted as the most severe corrosive point.
Posted 19 December 2014 - 10:25 AM
Dear Bhavinkumar
This has been observed beside of inhibitor injection for investigation of inhibition effect of it, or in condtion that offspec condtion laeds to corrosion this provision should be considered for abnormal condition(offspec condition lead to corroesion(example offspec dry acid gas on acid gas dehydration) .
Thank you
Thank you
Posted 20 December 2014 - 02:22 PM
Consult NACE2000
you can find details of corrosion coupon locations for hydrocarbon industery.
Toor
![]() Location Of Pts For HippsStarted by Guest__1angelia23_* , 10 Jan 2025 |
![]() Positive Displacement Pump Psv Discharge LocationStarted by Guest_QuantumEng_* , 24 Jul 2024 |
Check Valve LocationStarted by Guest_sn_sn_* , 26 May 2023 |
Natural Gas Wells Location And Production Volume DataStarted by Guest_ChinmoyBasak_* , 08 Feb 2023 |
Closed Cooling Water System Balancing Valve Preferred Location ?Started by Guest_go-fish_* , 14 Jul 2022 |
