Diesel Fuel Properties
dieselfuel density viscocity composition
#1 Hasam ullah
Hasam ullah
  • 4 posts
Posted 18 December 2014 - 01:14 PM
Hi everyone
                          Can anyone help me about the chemical composition of diesel. i have to design a heat exchanger. i need density, viscosity and other properties of diesel  at 100 0c and 176 0c. I did't find these properties for diesel directly. so I have to calculate the properties from diesel chemical composition.Any help please. I will highly appreciate your help.
Edited by Hasam ullah, 18 December 2014 - 01:16 PM.
#2 shan
shan
  • 692 posts
Posted 18 December 2014 - 02:00 PM
See the attachment
#3 P.K.Rao
P.K.Rao
  • 265 posts
Posted 19 December 2014 - 12:39 AM   Best Answer
Please  refer to ASTM D 975  for specifications of Diesel fuels.
        Grade
Kinematic Viscosity,                      1DC     2DC.D   1DE       2DD,E   4DE
mm2/S at 40°C D 445         min.    1.3       1.9       1.3       1.9       5.5
        max . 2.4     4.1      2.4      4.1     24.0
Kin Viscosity at 176 deg C has no specification. It differs from refinery to refinery. But if you are having density at 15 deg C and Kin Viscosity at 40 deg C, I can calculate at 176 deg C and give you
Density has no specification. But it will be in the range of 0.84 to 0.88 depending upon the type of hydrocarbons present in it and boiling range.
Diesel is composed of hydrocarbons of paraffinic, aromatic, naphthenic and olefinic having carbon atoms about 10 to 25 depending upon the boiling range 140 to 360 deg C  The chemical composition varies from refinery to refinery.
#4 Zauberberg
Zauberberg
  • 2,728 posts
Posted 19 December 2014 - 12:54 AM
If you have access to any of process simulators (Aspen, Pro/II etc.) you might build an assay for your diesel stream by using known properties at whatever reference temperature you have them, and let the software calculate properties at any other temperature.
Perhaps Maxwell's (Databook of Hydrocarbons) or Nelson's (Petroleum Refinery Engineering) books could help you as well.
#5 JMW
JMW
  • 166 posts
Posted 19 December 2014 - 11:10 AM
Another source of data is ISO 8217 (a google will bring you a number sites who have the details listed).
Like most standards they refer to the data at reference conditions. You need the data at specific conditions so you may find the spreadsheets in Cheresources useful: http://www.cheresour...wnloads&mid=987. In the file library you will also find some spreadsheets for heat exchanger sizing and so forth.
However, it is strongly recommended that you first of all become familiar with the underlying calculations and their history.
You should read for example, the Manual of Petroleum Measurement Standards and research the ASTM D341 calculations.
Spreadsheets are useful tools but are no substitute for first of all understanding the nature of the property you are interested in. Without this you will have no idea if the answers you get are to be relied upon or treated as a random number generator. Most calculations have some sort of limits to their applicability.
ASTM D341 is a log.log relationship. Such calculations need to be used with care.
Incidentally, why would you be heating diesel to 176C?
Unless what you refer to as Diesel is in fact something more viscous.
