2 Centrigugal Pumps In Series
centrifugal pump
30 replies to this topic
#1 Dmitry
Dmitry
  • 180 posts
Posted 09 January 2015 - 06:24 AM
What is the effect of running two centrigugal pupms in series. The first pump has less head/flow than second. I am looking for question is any impact on total head or total flow downstream all pumps?
Many thanks for answer
Dmitry
#2 Santoshp9
Santoshp9
  • 61 posts
Posted 09 January 2015 - 06:44 AM
Dear,the flow and head is depend on its upstream and downstream headloss.check loss upstream and downstream to both pumps and relate it with respective pumps characteristic curve.
#3 fallah
  • 5,019 posts
Posted 09 January 2015 - 06:46 AM
Dmitry,
In general, normally total flow and especially total head will be increased; but to evaluate precisely it should be investigated using two pumps curves and also the system curve...
#4 Santoshp9
Santoshp9
  • 61 posts
Posted 09 January 2015 - 06:47 AM
#5 breizh
  • 6,715 posts
Posted 09 January 2015 - 06:52 AM
http://centrifugal-p...lel_series.html
Dmitry ,
Consider reading the resource attached .
Edited by breizh, 10 January 2015 - 06:06 AM.
#6 gegio1960
gegio1960
  • 518 posts
Posted 10 January 2015 - 03:24 AM
the most important parameter is the shutoff pressure at the discharge of the 2nd pump (ie shutoff of shutoff)....
#7 Dmitry
Dmitry
  • 180 posts
Posted 26 January 2015 - 03:18 AM
Hello Dear,
Thanks for yours reply. The problem is that these pumps has different head/flow rates and engines power. I attached curves for both pumps
1-st. stage  pump (P-501)
2-nd. stage pump (P-503)
The pumps should pumped oil into 30 000 meters pipeline - 168 mm outside D., 8 mm wall thickness. Required pressure on pipeline outlet is 0,8 barg.
My question is will it works and what flow rate can we achieve with two pumps?
#8 breizh
  • 6,715 posts
Posted 26 January 2015 - 09:30 PM
Dmitry ,
Refer to the booklet page 103 ( pumps in series with different curves) . Of Course you need individual pump curve from vendor to be accurate then let you draw H versus Qv ; for pump in series H1+H2 @ Q=Q1=Q2 except the part where the characteristic  does  not cover the same range  : Q=Q1 = Q2 but  H =H1 or H2 only !
Of course you need to calculate the system curve and compare it with the pump curve ( 2 pumps in series) . The intersection will give you the operating point .
Hope this helps
#9 Dmitry
Dmitry
  • 180 posts
Posted 27 January 2015 - 12:48 AM
Dmitry ,
Hope this helps
Hello Breizh,
Thanks for your reply. Let me clarify above.
So I need to go to pumps manufacture and request individual curve H-Q? These existing curves can not give a full picture of pumps perfomance?
Then I need to add curves on one plot (as per Fig 3.2.6 - Two different sized pumps connected in series on page 103) - here I am confuse a little bit
Note that I've got a Aspen Hysys software, where I can put these curves in pump raring/curves tab. Can I model it as well?
Dmitry
#10 breizh
  • 6,715 posts
Posted 27 January 2015 - 01:20 AM
Yes Dmitry , you need to perform the exercise with accurate documents !
Sorry about Aspen I'm not knowledgeable .
#11 Dmitry
Dmitry
  • 180 posts
Posted 27 January 2015 - 01:25 AM
Ok, I requested vendor to provide these data. Could you give an exaple or similar or more details how to compare curves and how to calculate the system curve and compare it with the pump curve?
Dmitry
#12 breizh
  • 6,715 posts
Posted 27 January 2015 - 01:36 AM
Dmitry ,
Go to page 96 and following you will see what I'm talking ! most probably the pump curve (Pump1 +2 ) will be similar to fig  3.2.6 .
I cannot offer more right now.
Hope this helps
#13 breizh
  • 6,715 posts
Posted 28 January 2015 - 01:35 AM
Dmitry ,
Let you download PSIM on internet from AFT , go through the examples , there is one with a pump and pump curve . You can then build your own model with 2 pumps in series .
Input data : Fluid properties , System ( piping , material ,..) , pump curve (H vs Q, Efficiency , ..)
Output : Pressure , flow rate per section .
Good luck .
#14 Dmitry
Dmitry
  • 180 posts
Posted 02 February 2015 - 03:02 AM
Dmitry ,
Good luck .
Hello Breizh,
Thanks for advice, I went to AFT site - http://www.aft.com/psim
But there is problem with downloading this software, I will try to contact with them to check it.
Have you got experiance with this software? Can I do it only with software?
I attached accurate curves for both pumps, given by manufacture
Dmitry
Edited by Dmitry, 02 February 2015 - 03:12 AM.
#15 breizh
  • 6,715 posts
Posted 02 February 2015 - 03:48 AM
Dmitry,
yes it works fine !
What about the pumps which one is the right one 1,2,3,4 ( attachment) ? what about the system ? what about the properties of the liquid?
#16 Dmitry
Dmitry
  • 180 posts
Posted 02 February 2015 - 05:44 AM
Hello Breizh,
Please see data
Fluid - crude oil
Density - 720 kg/m3
Temperature - 8 deg. C.
Required flow rate - 201 bbls/d
Oil goes to first pump (LSN) thns to the second (RX)
From RX discharge oil goes to underground pipeline (D=168 mm, w.t.=8mm. lenght=30 000 m.) to the storage tanks
Required pressure on end of pipeline is 70 kpag
Dmitry
#17 breizh
  • 6,715 posts
Posted 02 February 2015 - 06:47 AM
Dmitry ,
Viscosity @ operating point?
Suction pipe pressure and altimetry ?
discharge pressure 70kpag , altimetry ?
distance between suction line and 1st pump ,
distance between the 2 pumps ,
Cross country flat ?
No valves , no bends ,no etc , just straight pipe from I guess a well or a Storage tank .
A Sketch will help !
RX125-400 , which curve is the correct one (1 or 2 or 3 or 4?
I'm trying to help you but you don't provide enough data .Did you ever design a suitable pump for a particular system ?
cheers
Edited by breizh, 02 February 2015 - 07:09 AM.
#18 Dmitry
Dmitry
  • 180 posts
Posted 02 February 2015 - 07:09 AM
Dmitry ,
RX125-400 , which curve is correct one (1 or 2 or 3 or 4?
cheers
Ok, I understood you, sorry for not all data
I will come back tp you later.
Dmitry
#19 breizh
  • 6,715 posts
Posted 02 February 2015 - 07:19 AM
Dmitry ,
Something is wrong , if I consider the pumps curves and the flow rate :201 bbl/d # 1.3 m3/h !
Please check you input data
#20 Dmitry
Dmitry
  • 180 posts
Posted 02 February 2015 - 10:11 AM
Dmitry ,
Sorry it's my mistake, the flow rate is in bbls/hr. Again sorry for it. I've sent request to manufacture about what curve for RX pump is correct. I am prepearing a sketch for piping now, so we can get all pipes lenghts, elbows numbers and valves.
Dmitry
#21 laketoba
laketoba
Posted 04 February 2015 - 01:45 AM
I plan to run pumps in series
4 x 25,000 bpd in series with 2 x 50,000 bpd
the pipeline length between 2 pumps is about 1 KM
What is industry best practice to protect the pipeline from vacuum? pressure switch low at suction of  downstream pump station is adequate or not?
Edited by laketoba, 04 February 2015 - 01:46 AM.
#22 Dmitry
Dmitry
  • 180 posts
Posted 04 February 2015 - 11:29 PM
Dmitry ,
Dmitry
Dmitry ,
Dmitry
Hello Breizh,
Please see data:
Oil storage tank T-500  - P-501 - P-503 - Oil export pipeline
Fluid - crude oil
Density  740 kg/m3
Viscosity 1,0 cP
Temperature  8 deg. C.
Pressure upstream P-501 25 kpag
Export ipeline (D=168 mm, w.t.=8mm. lenght=30 000 m.)
Ambient 0 deg. C, pipeline is inderground
Required pressure on end of pipeline is 65 kpag
What flow rate could be achieved using two pumps is series?
What pressure will be downstream P-501 and P-503?
#23 breizh
  • 6,715 posts
Posted 05 February 2015 - 01:35 AM
Dmitry ,
I' m confused .
What is the unit for length on your drawing ? mm, " ?  you mentioned 30 Km length  please clarify from where to where ?
Correct me , should be from P503 to export ? check your drawing .
What are the pressure in T 500 and Level ?
is the pressure Upstream P 501  stable and equal to 25Kpa g?
What is the delta P of the metering package ?
What is the distance between 2 pumps ?
No info about the pumps' curve : 1-2-3- 4?
Edited by breizh, 05 February 2015 - 01:36 AM.
#24 Dmitry
Dmitry
  • 180 posts
Posted 05 February 2015 - 03:51 AM
Dmitry ,
I' m confused .
Dear Breizh,
Lenght of export pipeline is 30 km
Yes, drawing is updated
Pressure is atmospheric, the level could be 12 meters above pump suction nozzle during start pumping and become 1 meters pump suction nozzle when pumping complete
Sorry, the pressure is tank is atmosphere
Delta P is 20 Kpag
2 meters, drawing is updated
Pump P-501 (LSN) is middle curve, I marked by red
Pump P-503 (RX) is curve 2, I marked by red
All files in attachments
Dmitry
#25 breizh
  • 6,715 posts
Posted 05 February 2015 - 11:29 PM
Dmitry ,
Based on the data you submitted and my understanding of your query , I found that the flow rate you can get with 2 pumps in series should be around 40m3/h taking account the level in the T500 ( 1-12 m) , the static pressure at the discharge of the first pump should be between 3.2 bars and 4 bars  and at the discharge of the 2nd pump between  6.2 bars and 7 bars  , the pressure at the outlet of the pipe ( after 30 km run) being 1.18 bar .
I encourage you to perform the exercise using whatever software or by hand .
Good luck .
