Pump Npsha And Suction Pressure
pump npsh suction pressure
7 replies to this topic
#1 Leonard W
Leonard W
  • 4 posts
Posted 25 January 2015 - 11:22 PM
I have a fundamental question regarding NPSH of pumps, in short, are NPSHa and suction pressure of a pump the same? I have searched through the forum and found numerous entries on NPSH but could not find one that answers my query.
While,
NPSHa = absolute pressure above liquid surface ± Suction Static - Friction Loss - Vapour Pressure
This is easily applicable for a pumping system which consists of an elevated open tank and a pump downstream of the tank's discharge. However, if a pump's suction pressure is provided by a booster pump upstream, how should then the NPSHa be calculated?
Please see the simplified pump system diagram as attached. I would really appreciate it if someone could provide answers on the following queries:
1) What is the difference between 'suction pressure' and 'NPSHa'?
2) Referring to the attachment, what should be the NPSHa for each of those pumps? (lift pump, booster pump and main pump)
Please help. Thank you.
  • 6,715 posts
Posted 25 January 2015 - 11:48 PM
http://www.engineeri...head-d_634.html
Leonard W,
Consider the link attached to support your query .
Hope this helps
#3 samayaraj
samayaraj
  • 239 posts
Posted 26 January 2015 - 12:55 AM
Leonard,
If pump 2 gets feed from pump 1, NPSH A for pump 2 = Pump 1 discharge pressure + static head - loss - VP
Pump suction pressure/ suction head = Pressure above liq surface / discharge pressure of booster pump + static head - loss
NPSH A = Pump suction pressure/ suction head - VP
With this, you can calculate the NPSH A for each pumps.
#Samayaraj
Edited by samayaraj, 26 January 2015 - 01:37 AM.
#4 breizh
  • 6,715 posts
Posted 26 January 2015 - 01:20 AM
Samayaraj ,
Pay Attention  to the definition , it's not the pump suction pressure to consider but the suction head (m)  - VP expressed in (m CL).
hope this helps
Edited by breizh, 26 January 2015 - 01:30 AM.
#5 samayaraj
samayaraj
  • 239 posts
Posted 26 January 2015 - 01:36 AM
Breiz,
Thanks for you comment. In general I said as pressure. While calculating we convert it into head. Ya its suction head (m) - VP (m). I've corrected it.
#Samayaraj
#6 fallah
  • 5,019 posts
Posted 26 January 2015 - 01:59 AM
Leonard W,
1) Pump suction pressure= Pressure above liquid surface+/- static pressure of liquid column-pressure loss in the suction line
While: NPSHa=Suction head-corresponding head of liquid vapor pressure
2)  NPSHa (Lift Pump)=15.44 m
     NPSHa (Booster pump)=27.44 m (assume 4 barg as discharge pressure))
     NPSHa (Main pump)=79.44 m (assume 8 barg as discharge pressure)
#7 Leonard W
Leonard W
  • 4 posts
Posted 26 January 2015 - 04:09 AM
Thank you all for the inputs. I have studied the contents from the link provided by Breizh which has provided clear explanation of suction head and NPSH. Samayaraj's input is also consistent with most materials that I found on NPSH.
With that, I would like to summarise my understanding of this topic and hope that you can verify if my understanding is correct.
According to replies from Samayaraj and Naser Fallah, I have come to understand that the basic formulas should be,
Suction head = pressure above liquid surface / discharge pressure from upstream pump ± static head of liquid column - head loss
NPSHA = Suction head - liquid's vapour pressure (m)
Since most texts only explain NPSH of a single pump and tank system, I was really looking to substantiate that the NPSH of a pump downstream of a booster pump should include 'discharge pressure from upstream pump' in the calculation. Is this conclusion correct?
#8 samayaraj
samayaraj
  • 239 posts
Posted 26 January 2015 - 11:32 AM
Ya you're correct.
#Samayaraj
