Steam Tracing Calculation For Vessel Heat Loss
tracing heat loss
#1 mbsahg
mbsahg
  • 30 posts
Posted 09 March 2015 - 08:50 PM
Hello~
I am trying to design from steam tracing  for vessel.
The purpose is the temperature maintenance.(about 120℃)
I know that the temperature maintenance is usually installed internal the coil.
But our client wants to install a coil on outside of vessel.
I am needing any method to calculate steam tracing length.
Thank you for reading message~^^
  • 6,715 posts
Posted 09 March 2015 - 09:52 PM
http://www.thermon.c...ignsupport.aspx
Consider this resource to support your work .
#3 mbsahg
mbsahg
  • 30 posts
Posted 10 March 2015 - 06:09 AM
Thank you for your reply.
But, Thormon product is special item.
I want to use general steam tracing by tube or pipe.
Have a good day~^^
#4 breizh
  • 6,715 posts
Posted 10 March 2015 - 06:44 AM
hi,
you should read carefully , there is a part related to steam tracing (under software)
Have a good day too.
Edited by breizh, 10 March 2015 - 06:45 AM.
#5 mbsahg
mbsahg
  • 30 posts
Posted 11 March 2015 - 08:26 AM
hi,
Hi
Thank you for your help
I am installed the software to supply from Thermon manufacture.(Software name: CompuTrace VT)
But the software should be selected a steam tracer of product of Thermon manufacture.
I am not able to attach a captured image file.  because i don't know  method to attach a file. :(
The tracer type is only 'Heet Sheet'(HS-2, HS-4, HS-8)
I am posted to my blog a capture file.
http://blog.naver.co...g1/220297271612
Thank you for reading message.
