Estimating The Viscosity Of Crude Oil
14 replies to this topic
#1 process16
process16
  • 46 posts
Posted 04 April 2015 - 05:09 AM
hello
i need to know the viscosity of a crude oil with a specific gravity of 0.760 in a diff temperatures
we  dont have  a lab  to do TBP  test  so i need a  graph of estimation
does any one  have  an idea??
Edited by tarek12, 04 April 2015 - 07:52 AM.
#2 P.K.Rao
P.K.Rao
  • 265 posts
Posted 04 April 2015 - 07:04 AM
For knowing viscosity, you don't have to do TBP. Just do viscosity at any temperature and density at any temperature. Come back to me with this data. I will give approximte viscosities of the same material from 40 to 100 deg C.
#3 process16
process16
  • 46 posts
Posted 04 April 2015 - 07:43 AM
this is the  prob  we  dont have the TBP, all what do we know is the specific gravity
i  dont know if there is an estimating  or no?
#4 marchem
marchem
  • 153 posts
Posted 04 April 2015 - 08:00 AM
as said P.K.Rao to obtain an accurate estimate you should start from some measured value for viscosity,
API TDB includes some methods as for example Abbot et Al. which allows to estimate kinematic viscosity from API gravity and Watson characterization factor, there are also other methods which you may consider depending from data available
#5 PingPong
PingPong
  • 1,466 posts
Posted 04 April 2015 - 09:14 AM
Oil with a specific gravity of 0.760 (55 API) is normally called a condensate, not a crude oil.
But that does not really matter, because, just as crude oils, condensates have a name.
With that name you should be able to find all properties of the stuff.
#6 P.K.Rao
P.K.Rao
  • 265 posts
Posted 04 April 2015 - 09:28 AM
Yes. UOP 375 gives UOP K (Watson Charecteriztion Factors) from Viscosity and API Gravity. But they are applicable to petroleum distillates. Please see the scope of the method:
"This method is for calculating the UOP Characterization Factor of petroleum oils from API gravity and
distillation or viscosity data. Average molecular weight of petroleum oils is estimated from API gravity and
distillation data. The UOP Characterization Factor, commonly called K, is indicative of the general origin
and nature of a petroleum stock. Values of 12.5 or higher indicate a material predominantly paraffinic in
nature. Highly aromatic materials have characterization factors of 10.0 or less."
For calculating UOP K, ASTM D 86 or ASTM D 1160 distilaation values are required. These methods are not applicable to crude oils. I will calculate and give by separate method which I developed but yet to publish.
#7 process16
process16
  • 46 posts
Posted 04 April 2015 - 09:38 AM
its an algerian crude oil, this is why the specific  gravity is low
#8 Napo
Napo
  • 350 posts
Posted 04 April 2015 - 09:52 AM
Dear Tarek12,
You can do an estimation by means some correlations, but you need to take precautions.
I send you information. I hope help you.
Your crude oil is very light, 54.7 °API (= 0,76 SG), Whats is the crude oil name?.
Napo.
#9 process16
process16
  • 46 posts
Posted 05 April 2015 - 08:29 AM
well thank  you freinds , for whom asked about the crude  oil
its  an algerian crude  oil  with a  specifique  gravity  of 0.760 at 20°c as  i said  befor
i wanna do a  tubulair  heat exchanger  calculation , this is why iam asking about  viscosity
well i got  a file about Kuop of the  crude  oil
Kuop =12
So how  we can get viscosity?
about thermal conductivity is  there an idea to get prcise  value  or i can  use  just general chart????
thank u!!!
Edited by tarek12, 05 April 2015 - 08:37 AM.
#10 P.K.Rao
P.K.Rao
  • 265 posts
Posted 05 April 2015 - 09:57 PM
If you have got KUOP, it is fine. Use UOP 375 method. Caculate API gravity. From K UOP and API Gravity, and the profiles given in UOP 375, you can get Viscosities at 100 deg F, 122 deg F and 210 deg F. From any of these two viscosities, calculate viscosity at any other  desired temperature using the viscosity-temperature relation,
loglog(V) = A + B*log(T). T is the absolute temperature degrees Kelvin or degrees Rankine and V is the viscosity at temperature T (cSt or SUS)
or use ASTM D 341
A and B are constants
Edited by P.K.Rao, 08 April 2015 - 09:53 PM.
#11 PingPong
PingPong
  • 1,466 posts
Posted 06 April 2015 - 04:41 AM
The name of the country is not the same as the name of the crude oil.
I know Algerian Condensate (~65 API) and Saharan Blend (~45 API) but I never saw an Algerian crude oil or condensate of 55 API.
Moreover a K-UOP of 12 is very low for a crude oil or condensate of 55 API.
#12 JMW
JMW
  • 166 posts
Posted 11 April 2015 - 11:51 AM
PK Rao refers to the ASTM D341 viscosity temperature equation. There is a spreadsheet for this calculation here: http://www.cheresour...wnloads&mid=987
#13 Chellani
Chellani
  • 78 posts
Posted 13 April 2015 - 02:10 PM
Crude assay is the most reliable source for viscosity. I know that there are few (rather a lot of) correlations available but none of them is reliable. Few process simulators are also using these correlations but users always have problem when they don't provide viscosity of cuts in the crude assays.
#14 PingPong
PingPong
  • 1,466 posts
Posted 14 April 2015 - 02:52 AM
I fully agree with you.
#15 titim
titim
  • 76 posts
Posted 14 April 2015 - 08:35 PM
i from algeria, and i work in a refinery, an algerian crude with 0,76 SG??? it's a condensate note a crude 'sahara blend
