Co2 Purification Using Activated Carbon
12 replies to this topic
#1 Pressure Vessel Design
  • Store Customers
  • 42 posts
Posted 05 April 2015 - 11:34 AM
I am currently designing an activated carbon column to purify CO2 gas and remove VOC and ethanol. I have done some research concerning the adsorption of CO2 onto activated carbon however, I am still unsure of how the process works. I am aware that to recover the CO2 once it has been adsorbed is by desorbing however won't some of the VOC be recovered with the CO2?
I apologise for my lack of understanding I have very limited understanding on the adsorption process.
Posted 05 April 2015 - 03:03 PM
What, exactly, is your gas feed mixture composed of and WHAT are you removing (adsorbing)?
#3 Pressure Vessel Design
  • Store Customers
  • 42 posts
Posted 06 April 2015 - 04:50 AM
Hello Art Montemaryor,
Thank you very much for your reply I apologise for my lack of information
My gas feed mixture consists of:
99% CO2
0.6% ethanol
0.1% ethyl acetate
0.2% 3-methyl-1-butanol
0.1% 2-methyl-1-butanol
0.02% phenylethyl alcohol
0.04% ethyl octanoate
At a flowrate of 135240.66 kg/day. This gas mixture was formed during the fermentation of molasses with s.cerevisiae to produce ethanol.
My purpose is to purify the CO2 to >99.9% by removing the ethanol and the VOC's (ethyl actetate, 3-methyl-1-butanol..etc). From research I found that CO2 is adsorbed when using activated carbon but that it can be regenerated to recover the CO2. I've found that quite a lot of industries are using activated carbon to remove VOC's formed in the fermentation process and purify the CO2. I apologise for my lack of understanding I haven't yet found a clear explanation of how the process works.
#4 breizh
  • 6,715 posts
Posted 06 April 2015 - 05:36 AM
First step should be a water scrubber to eliminate the alcohol before using AC .
My 2 cents
#5 Pressure Vessel Design
  • Store Customers
  • 42 posts
Posted 06 April 2015 - 05:44 AM
Hi Briezh,
My original design was to use a water scrubber to eliminate the alcohol however after conducting sample calculations a design couldn't be developed, after speaking to my supervisor I noticed that my values do not meet the design criteria for a water scrubber. Instead I condensed off the alcohol and separated it using a flash drum with the advise from my supervisor.
This stream containing 99% CO2 1% VOC's would then enter the AC.
#6 breizh
  • 6,715 posts
Posted 06 April 2015 - 07:20 AM
It's what I saw in the ethanol plants (3 ) I visited last year . At that time I was investigating a way to recover CO2 from fermentation .
Probably for greater purity you need a second step , why not adsorption using AC?
#7 Pressure Vessel Design
  • Store Customers
  • 42 posts
Posted 06 April 2015 - 07:29 AM
Hi Briezh,
Thank you very much for for your quick reply. Yes that's exactly what I am investigating at the moment, adsorption using AC. I understand the adsorption concept but I am unsure of the adsorption process using AC to purify CO2 and eliminate VOC. I found that CO2 is adsorbed onto the AC and to recover the CO2 a second step is necessary known as regeneration. I am just very unsure with how the process happens and I apologise for my lack of understanding.
#8 breizh
  • 6,715 posts
Posted 06 April 2015 - 07:48 AM
Another resource about CO2 purification is attached  .
http://www.union.dk/...dustrial-gases/
Good luck .
Edited by breizh, 06 April 2015 - 08:18 PM.
#9 Pressure Vessel Design
  • Store Customers
  • 42 posts
Posted 07 April 2015 - 10:41 AM
Hi Breizh,
Thank you very much for your help. I am still trying to figure out the process of purifying CO2 with AC, I think it may have to do with the pore size and particle size of the components to attach themselves to the AC. But, I am still trying to figure out the kinetics and process.
Thank you again
#10 breizh
  • 6,715 posts
Posted 13 April 2015 - 07:00 AM
Pressure Vessel design ,
late information .
#11 Napo
Napo
  • 350 posts
Posted 15 April 2015 - 06:12 PM
Dear Breizh,
I can“t download the last attatched: "Adsorption Manual US Army.pdf"
Can you help me?, or it is the same attached in this post.
Many Thanks.
Napo.
#12 breizh
  • 6,715 posts
Posted 15 April 2015 - 06:14 PM
yes it is .
#13 Pressure Vessel Design
  • Store Customers
  • 42 posts
Posted 18 April 2015 - 02:15 PM
Thank you very much Breizh the documents helped a lot, I have come to understand how to design it for a multicomponent gaseous stream
