Hi All,
I have a problem relating to OIW Analyzer need your support. Our FPSO is dealing with a huge amount of sand coming from wells. As a result, the excessive sand carry-over to produced water overboard hence the analyzer will not record correct readings.
OIW range: 0-40 ppm.
Has anyone experienced the same case, please advise me some recommendation on vendor/ model which is good for OIW analyzer.
- In-line or side- stream type is better. The existing one is side-stream type
- What's maximum solid particle size?
- Any advanced technologies for this case?
Thank you so much.
vnpetroleum
