Priming System For Centrifugal Pumps
#1 akv_csl
akv_csl
  • 8 posts
Posted 21 May 2015 - 02:55 AM
Does a priming system is essential for centrifugal pump, other than start up situation. for example if we are transferring from one tank to another tank. The tank from which pump suck the fluid will not be empty completely, say liquid will be above the bell mouth. In this case do we need to prime pump each time during start up.
Thanks in advance
Arun
  • 6,715 posts
Posted 21 May 2015 - 03:07 AM
Arun ,
This subject has been discussed many time , consider using the search engine in this forum .
The risk is about cavitation & vapor lock.
Hope this helps
Edited by breizh, 22 May 2015 - 03:36 AM.
#3 fallah
  • 5,019 posts
Posted 21 May 2015 - 08:02 AM
Arun,
If pump trips on LL liquid level then it might there would be no need priming per each start up; otherwise before each start up the requirement to priming should be checked
#4 Pronab
Pronab
  • 166 posts
Posted 21 May 2015 - 12:14 PM
Yes in a centrifugal pump priming is required.
#5 samayaraj
samayaraj
  • 239 posts
Posted 21 May 2015 - 08:40 PM
If the discharge pressure is rated pressure and is stable, you no need to do priming. Else you have to do priming. I have seen for a cooling tower circulation pump where the discharge pressure keep on hunting during start up thought the pump is flooded (pump is below the cooling tower water basin). Due to lack of sufficient head in water basin, air is getting entrapped at every start up.
#6 akv_csl
akv_csl
  • 8 posts
Posted 25 May 2015 - 04:26 AM
Thank you all for your valuable comments
