Chazop Guide Words
chazop
#1 ChemEng01
ChemEng01
  • 84 posts
Posted 02 June 2015 - 02:46 AM
Hey Guys
I'm attending a CHAZOP (Hazard and Operability Studies for Control Systems)
While I have been part of many HAZOPs, this is my first CHAZOP.
Has anyone got any good information for CHAZOPs. (Especially typical guide words / deviations)  I am developing some guide words (or deviations) as you would for a HAZOP. Each deviation will be looked at for the control system and causes / consequences / safeguards / actions will be done as per a typical HAZOP.
For the deviations I'm thinking along the lines of, for example
NO OR NOT OR LESS
No or Less Power
No or Less current / signal
Lost data
Data rate too slow
MORE
High volts / amps
High alarm rate
REVERSE
Transmit when should be recieving
etc etc.....
I'm just making them up at the moment. Does anyone have a list of typical CHAZOP deviations?
Normally for a HAZOP the deviations are pretty standard (i.e More / less flow, temp, pressure. Reverse or missdirected Flow, etc etc) and most companies or clients have a list of standard deviations.
Any guidance much appreciated
#2 Zauberberg
Zauberberg
  • 2,728 posts
Posted 02 June 2015 - 02:26 PM
See attached material, Section 4 in particular.
Try to obtain the book "Process Automation Handbook - A Guide to Theory and Practice" by Jonathan Love. There is a paragraph dedicated to CHAZOP. I think you can also find it on Google books.
#3 Zauberberg
Zauberberg
  • 2,728 posts
Posted 02 June 2015 - 02:31 PM
Here it is - I have a soft copy with me. You can see some common guidelines used.
#4 ChemEng01
ChemEng01
  • 84 posts
Posted 03 June 2015 - 02:31 AM
Thats great!
Thanks a lot Zauberberg.
