Hi there.
I'm dealing with a preliminary design of a API tank separator, which receives a 5,000 m3/d feed stream with 30% water cut. Water has 1.010 sp gr, oil has 0.92 sp gr, both at 50 °C, and dry oil viscosity is 455 cP at this temperature. This is all my input data, all that I get.
Beside of emulsion effect and droplet size distribution, I wonder ( ) if I have to take a special consideration with this heavy oil, I mean, should I have to consider a viscosity correction? shear rate correction? is there a correlation or empirical equation for preliminary sizing of API tank separators with non newtonian heavy oils ?
Thanks in advance.
Non Newtonian Oil / Water Separation (Heavy Oil)
Posted 27 July 2015 - 08:12 PM
Posted 27 July 2015 - 10:43 PM
What you must do is heat the oil to reduce the viscosity. At least.
Posted 27 July 2015 - 11:01 PM
And (besides what Mr Strain said above), use a suitable demulsifier to break emulsion.
Edited by P.K.Rao, 27 July 2015 - 11:02 PM.
Posted 28 July 2015 - 11:15 AM
Posted 28 July 2015 - 01:16 PM
Posted 28 July 2015 - 04:49 PM
Sorry by my english. I mean that my imput condition are those that I mentioned.
I can not increase feed stream temperature nor use a chamical demulsifier.
My question is simple: I am dealing with a non newtonian fluid, should I take a special consideration with viscosity?
Posted 28 July 2015 - 06:35 PM
So, are you a student? And this is an assignment?
Posted 14 August 2015 - 03:14 AM
Is this the best way to do it?
A good question I would have thought.
In marine heavy fuel oil applications a centrifuge is used at 98C.
(Google- Alpha Laval).
Posted 17 August 2015 - 02:08 PM
Hi Jaluerol,
If your fluid is so viscous that its exhbiting a non-newtonian behaviour .. on top of that if it has emuslion ... then API separator might not be abe to do any thing except giggle.
API separator if sized with terminal velocity and relative viscosity equations cannot handle the emulsions nor the non newtonian fluid behavior ....
just to separate by putting in API you will need to size a very big API separator with a big residece time. You can ask them for a lab scale test to see how long it takes to separate te phases ... then use thatt info ... and you will be amazed ... (do keep us posted what you find)
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
