How To Calculate Density Of Liquids At Different Temperature
#1 Krishna Mohan
Krishna Mohan
  • 5 posts
Posted 13 August 2015 - 03:38 AM
i want to calculate the liquid density using the following correlation
to get density from this formula i need the A,B,C,D values for amines and other components
can you please tell me the source ,to get those details.
can you please suggest any alternative method to calculate liquid density
Edited by Krishna Mohan, 13 August 2015 - 03:39 AM.
#2 shan
shan
  • 692 posts
Posted 13 August 2015 - 06:17 AM
Density = mass/volume
#3 breizh
  • 6,714 posts
Posted 13 August 2015 - 06:18 AM
Consider the attachment ! You need a subscription to get access to this data base . No free lunch !
Note : Google " Liquid density estimation method " to support your work or try to find technical bulletin of your products through Internet or call vendor of those chemicals .
Good Luck.
Edited by breizh, 14 August 2015 - 12:44 AM.
#4 P.K.Rao
P.K.Rao
  • 265 posts
Posted 13 August 2015 - 08:53 AM
Use ASTM D 1217 Density of  Liquids by Bingham Pycnometer. You can calculate at three or four temperatures, 10 to15 deg C apart, plot a graph (which should be nearly a straight line) and interpolate or extrapolate as needed within the temperatures at which the material is a liquid. Avoid temperatures near boiling point and freezing point.
#5 P.K.Rao
P.K.Rao
  • 265 posts
Posted 13 August 2015 - 09:33 AM
By using four densities, as obtained above, you can determine the constants in your equation by elimination
#6 ezralh
ezralh
  • 32 posts
Posted 13 August 2015 - 09:46 AM
Simulation software (ASPEN, Chemcad) is the quickest way.I think all A to D in the equation for common organic compounds can be found in "Thermophysical Properties of Chemicals and Hydrocarbons".
#7 Krishna Mohan
Krishna Mohan
  • 5 posts
Posted 14 August 2015 - 04:58 AM
Thank you
