How To Calculate Z Factor
z factor
8 replies to this topic
#1 Bayan
Bayan
  • 4 posts
Posted 19 August 2015 - 11:05 PM
Hello
Please help me with following issue.
I have two gases. Natural gas and Sour gas. With known component fraction(constant). All the time I need to estimate z factor for different range of T and P for each gas.
Can you advice formula to do it more accuracy?
#2 shvet
shvet
  • 135 posts
Posted 19 August 2015 - 11:18 PM
You can convert gas density to Z using formula.
Z = P*M/8.31*p*T
where P is pressure in kPaa
           M is molecular weight
           p is density in kg/m3
           T is temperature in °K
Density of gas you can calculate using a lot of math methods using software, for example Simsci Pro II or Hysys. You can ask here for help.
#3 Bayan
Bayan
  • 4 posts
Posted 20 August 2015 - 12:51 AM
Sorry for misunderstanding. I need Z factor for calculating gas Volume at P and T
#4 serra
serra
  • 311 posts
Posted 20 August 2015 - 01:52 AM
you may find several Excel pages in this forum,
there are many correlations which may be useful, see for example
"http://petrowiki.org...r_for_sour_gas"
of course as suggested by shvet you may use a software (I have Prode Properties) which returns Z, density etc.
#5 Bayan
Bayan
  • 4 posts
Posted 20 August 2015 - 03:17 AM
I want to do all calculation in Excell.  You know I have Hysys programm, but every time to entering P and T for certain gas it's take time(We have many calculation). I want to make Excell file and calculate once all things for Sour Gas and Fuel gas(their component composition is constant). and after putting P and T to know Z and V(to know the volume of gase is the goal).
#6 serra
serra
  • 311 posts
Posted 20 August 2015 - 06:51 AM
if you know Z at regular intervals on a P-T grid you may interpolate V = ZRT/P
for Z (or density) if you wish to calculate accurate values a iterative solution (EOS or the correlations mentioned in my previous post) is suggested, however that may run slow in Excel,
for a fast solution you may install a process library (see my previous post) or link with a external software,
I prefer a process library but if you own a simulator then you may use that...
#7 Bobby Strain
Posted 20 August 2015 - 09:06 AM
HYSYS and Excel is all you need. Hook them together.
#8 MrShorty
MrShorty
  • 517 posts
Posted 20 August 2015 - 10:11 AM
Z is used for different quantities in different contexts. In this case, I assume we are all talking about the "compressibility" factor, since it looks like we are all talking about PVT properties of fluids.
Two basic approaches that I see for computing compressibility (whether you use Excel or simulator or slide rule):
Take PVT data and plug into the basic "ideal" gas law: PV=ZnRT. Solve for Z.
Choose an appropriate equation of state, and solve that equation for "Z".
I assume that you want to use this latter approach. Since you have not specified which EOS you want to use, I will simply refer you to Wikipedia's EOS page. https://en.wikipedia...uation_of_stateThe basic approach that I see:
1) Choose EOS
2) Collect pure component and mixture data needed by EOS (critical properties, binary interaction parameters, EOS specific parameters, other??).
3) Solve EOS for given mixture composition, T, P to get V and or Z.
Of course, the details of 2 and 3 will depend on the EOS chosen in 1.
#9 breizh
  • 6,714 posts
Posted 20 August 2015 - 06:07 PM
Hi Bayan ,
You may use the excel sheet attached to perform your work . Follow the recommendation given above  and key in the different parameters associated to the mixture .  Apply Kay's rule for pseudo critical parameters .
attached a data base where you can find the properties of pure components :
http://www.cheric.or...rop/cmpsrch.php
Hope this helps
Edited by breizh, 22 August 2015 - 03:29 AM.
