Internal Floating Roof Tanks
#1 m42364236k
m42364236k
  • 94 posts
Posted 27 August 2015 - 01:07 AM
Dear colleagues
for internal floating roof does it need to consider the nitrogen blanket
i mean maybe we have leakage from rim seal
do we have any standard or criteria to use nitrogen for internal floating roof?
Second question
do we consider the roof failure as case
if the roof failure happen what kind of protection we should consider?
Mike Court
#2 fallah
  • 5,019 posts
Posted 27 August 2015 - 02:17 AM
Second question
Mike,
As far as I know, there is no specific standard for using N2 blanket in IFR...
It's supposed the rim seal has no leakage and any vapor would be released through the rim vent...
What do you mean by roof failure? Please specify the type of failure...
#3 m42364236k
m42364236k
  • 94 posts
Posted 27 August 2015 - 04:08 AM
Second question
Mike,
Fallah thanks for your reply
roof failure means due to some problem roof don move upward and downward with fluid ,and in this situation when we start to empty the tank with pump (out breathing)vacuum happen ,or when we start to fill the pump (breathing)pressure increase and cause to damage the
tank
thanks
mike
#4 fallah
  • 5,019 posts
Posted 27 August 2015 - 10:50 AM
roof failure means due to some problem roof don move upward and downward with fluid ,and in this situation when we start to empty the tank with pump (out breathing)vacuum happen ,or when we start to fill the pump (breathing)pressure increase and cause to damage the tank.
mike,
What you described, don't appear to be roof tank failure for an IFR. It is natural when the roof would move upward or downward due to filling or emptying...please clarify with a reasonable detail...
#5 m42364236k
m42364236k
  • 94 posts
Posted 28 August 2015 - 12:46 AM
mike,
Can we consider the possibility of internal roof damage and don’t move upward or down ward?
my question is if this case happen for example when  the pump started to empty the tank ,in general condition  the roof move down ward with fluid , but what happen if the roof don’t move downward? i think vacum will be happen under the roof
mike
