Has anyone ever had the following error when starting up AspenPlus?
"Failed to initialize the Aspen Properties Enterprise Database.
Posted 05 October 2015 - 10:30 AM
Posted 05 October 2015 - 10:34 AM
when I run the config tester it spits out this in a notepad file
Posted 05 October 2015 - 11:41 AM Best Answer
I suggest you go to https://support.aspentech.com/ for technical support. Your error message is addressed there as a result of other users with this problem.
Posted 02 November 2015 - 09:38 PM
Hello , I have exactly the same issue (Failed to initialize the Aspen Properties Enterprise Database) . Does somebody have a solution ? Thanks
Posted 09 November 2015 - 10:34 AM
Misamate,
I figured out that my temporary admin rights on my computer had expired before aspen finished installing. I had to uninstall and reinstall all of aspen to get this to work.
good luck
Posted 17 November 2015 - 03:59 AM
Dear Chrbc,
Are you still facing the same problem after reinstalling? I am facing the same problem with version 8.4 and after reinstalling the problem is still there. I am using windows 10 pro 32 bit and have tried both 2012 and 2014 version of sql server(mixed mode authentication ). What version of microsoft os you are using? Do you have any other possible solution?
Thnx
Posted 21 December 2015 - 12:45 AM
After installing Aspen 8.4 with windows 8, have not faced the problem. It may be the problem of Aspen 8.4 with windows 10 .
Posted 18 February 2016 - 09:54 AM
Hi everybody!!
I have the same problem with Aspen V8.4, on Windows10.
Did anybody find a solution??
I cannot consult the official forum that @Pilesar linked, can anyone tell me if they propose a solution there??
Posted 01 March 2016 - 03:13 AM
GiacomoF,
yes, the problem is with windows 10. Aspen 8.8 is working perfectly on Windows 10 and if possible use Aspen 8.8.
Bitan
Edited by Bitan729, 01 March 2016 - 03:17 AM.
Posted 26 July 2016 - 12:16 PM
Hi, I don't have a good writing...so basically I got the same error message...but I wanted to launch Aspen Hysys 8.4 without the APED problem ( None of specified aped databases are accessible, hence you cannot use....).
So I'll make it easy and I'll write what I did. It's important to say that I had windows 8.1 then I got Windows 10 Home, and the rest you know.
1. First, launch Database Tester - Aspen Properties v8.4. Press start and if you are lucky it will fix the connections. In my case the last message was the creating: config.aem. So that's basically the problem. But if you got many errors (Like me) try the following:
2. Lines Above Britan 729 explains how to configure SQL Server. So I had to uninstall...try to install...update...and finally install. Don't forget to put Mixed mode Authentication.
3. Download: Aspen Engineering - Installation Guide (154 pages) Or mail me.
4. In page 83 follow the steps of Configuring Microsoft SQL Server until page 91. The firewall part...for me it was impossible. So I skipped that part.
So that's all. Hope you can fix that problem.
Saludos,
Hugo Mena
Posted 23 July 2017 - 08:25 AM
[FIXED]
To fix this issue on Aspen 8.4 on Windows 10, I did as follows
Finally, your config.aem file will be created.
Hope be useful,
Cheers.
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
Physical Properties Of Liquid Discharge For Kod SizingStarted by Guest_mahmooddalvi09_* , 26 Feb 2025 |
No Liquid Phase In Aspen PlusStarted by Guest_PengRobinson_* , 09 Feb 2025 |
