Fan Power Calculation
fan power calculations
14 replies to this topic
#1 Bal
Bal
  • 89 posts
Posted 18 October 2015 - 06:34 AM
How to calculate the electrical power needed to operate a fan? I know the duty of the fan.
#2 fallah
  • 5,019 posts
Posted 18 October 2015 - 07:15 AM
Bal,
For quick estimation:
HP=(CFM*PSF)/(33000*Efficiency); where:
CFM: Cubic Feet per Minute): Delivered Volumetric Flow Rate
PSF: Pounds per Square Foot): Total pressure Increase
#3 Bal
Bal
  • 89 posts
Posted 18 October 2015 - 08:44 AM
Thanks a lot Naser.
what typical values for efficiency and PSF can I assume (for a simplified solution)?
#4 fallah
  • 5,019 posts
Posted 18 October 2015 - 10:55 AM
Bal,
Typical value for PSF is 100 (should be below around 300) and typical value for efficiency is around 70%...
#5 Bal
Bal
  • 89 posts
Posted 18 October 2015 - 11:32 AM
Thanks.
One last question: where can I find this equation? cz i need the reference
#6 Bal
Bal
  • 89 posts
Posted 18 October 2015 - 01:03 PM
Is it related to the one in GPSA?
CFM is the flow rate of the fluid or the air?
#7 breizh
  • 6,714 posts
Posted 18 October 2015 - 06:46 PM
Hi Bal ,
Consider the excel sheet attached to support your work
Edited by breizh, 18 October 2015 - 07:58 PM.
#8 Bobby Strain
Posted 18 October 2015 - 07:48 PM
I found this among my collection. Maybe it still works.
#9 Bal
Bal
  • 89 posts
Posted 18 October 2015 - 10:40 PM
Thanks a lot Breizh and Bobby.
#10 Bal
Bal
  • 89 posts
Posted 01 November 2015 - 11:19 AM
Bal,
How to calculate CFM?
is there any rules of thumb?
#11 fallah
  • 5,019 posts
Posted 01 November 2015 - 11:31 AM
When it's intended the fan power to be calculated; the required CFM has to be specified by whom is performing such calculation...!
#12 Bal
Bal
  • 89 posts
Posted 01 November 2015 - 11:43 AM
That's true, but I'm trying to estimate the fan power for a project and I can't deny my lack of knowledge this area.
The only information in my hand is the duty of the air cooler (2.73 e6 BTU/hr).
The procedure in the GPSA is lengthy and considers some design details that I don't actually need.
I found another book (rules of thumb of chemical engineers by Carl) and it gives a shorter path for calculating the fan power, but I can't use it even because it requires ACFM value and number of tube raws (I don't care about this one).
I realized that you can't proceed with the fan power calculations without the ACFM,,,,but
Is there anyway to relate the ACFM needed with the duty of the fan?
#13 Bal
Bal
  • 89 posts
Posted 01 November 2015 - 11:45 AM
Q=M Cp dl T??
#14 fallah
  • 5,019 posts
Posted 01 November 2015 - 11:59 AM   Best Answer
Bal,
One BTU/hr is almost equal to 0.3 watts...Then considering a typical value of efficiency equal to 70% you can easily estimate the fan power value...
#15 Bal
Bal
  • 89 posts
Posted 01 November 2015 - 12:11 PM
Thank you very much
