Hello Cheresources Community,
I have a question regarding the handling calculation of the absorbed duty in a Fired Heater. I just received a data sheet from the client and I will like to check the absorbed duty reported on it. I perform some calculations but I get different results. I think, I have some trouble with the calculation of the Heat of Vaporization.
This is the data I have available:
Absorbed Duty: 67.53 MMBTU/hr
Fluid Name: Naphtha+H2
Total Flow Rate: 1092200 Lb/h
Inlet Conditions
Temperature, ºF=578
Pressure, psig=259
Liquid Flow Rate, lb/h= 943400
Vapor Flow Rate, lb/h= 148800
Liquid Gravity= 0.533
Vapor Molecular Weight= 78.3
Viscosity Liq / Vap, cP= 0.088 / 0.016
Specific Heat Liq / Vap, BTU/lb-ºF= 0.788 / 0.678
Thermal Conductivity Liq / Vap, BTU/hr-ft-ºF= 0.0357 / 0.0486
Outlet Conditions
Temperature, ºF= 625
Pressure, psig= 232
Liquid Flow Rate, lb/h= 543400
Vapor Flow Rate, lb/h= 548800
Liquid Gravity= 0.505
Vapor Molecular Weight= 120.5
Viscosity Liq / Vap, cP= 0.074 / 0.014
Specific Heat Liq / Vap, BTU/lb-ºF= 0.847 / 0.694
Thermal Conductivity Liq / Vap, BTU/hr-ft-ºF= 0.034 / 0.035
I highly appreciate your help.
