To Close Vent Hole For Bellow Psv
7 replies to this topic
#1 farid.k
farid.k
  • 384 posts
Posted 13 November 2015 - 11:05 PM
Is it allowed to close the venting hole at bellow PSV due to leak problem? I don't think so as it will cause problem for the PSV to open due to excessive backpressure. Any other method how to recover the leak at bellow PSV?
#2 latexman
  • 1,809 posts
Posted 14 November 2015 - 02:25 AM
I can think of two solutions.  The vent hole can be vented (piped) to a treatment system, as long as no significant backpressure results.  I would assume you'd want to detect the leaking bellows in this case.  Or, you can select a pilot operated PSV instead of a bellows PSV.  This would eliminate the bellows.
I'm not sure if a rupture disk (or buckling pin valve or another different technology relief device) instead of the bellows PSV could be a solution to you, or not.
Edited by latexman, 14 November 2015 - 02:27 AM.
#3 farid.k
farid.k
  • 384 posts
Posted 14 November 2015 - 02:35 AM
Is it OK to route piping to the safe location? I did go through some other forum and said the same but is it normal practise for bellow PSV leaking?
We cannot down the system thus cannot replace the relief valve.
#4 fallah
  • 5,019 posts
Posted 14 November 2015 - 03:10 AM
farid.k,
Yes, you can pipe away the bonnet vent to a safe location; but it's a normal practice just for the cases that cannot be directed to the close atmosphere, e.g. toxic or high flammable gases...
#5 farid.k
farid.k
  • 384 posts
Posted 14 November 2015 - 03:59 AM
Flammable gas route to flare?
#6 fallah
  • 5,019 posts
Posted 14 November 2015 - 04:08 AM
farid.k,
To safe location (atmospheric pressure); because firstly the flow just limited to minor leakage and secondly hasn't (and in fact shouldn't have) any positive pressure to be able being routed to flare....
#7 farid.k
farid.k
  • 384 posts
Posted 14 November 2015 - 04:52 AM
Thanks fallah and latexman for the support
Edited by farid.k, 14 November 2015 - 04:56 AM.
#8 latexman
  • 1,809 posts
Posted 14 November 2015 - 09:04 AM
farid.k,
You are most welcome.  Don't forget though, a leaking bellows should be replaced/repaired at the first convenient opportunity.  If the openings in the bellows continue to get larger and larger (corrosion, fatigue, etc.) there will come a day when the bellows PSV loses it relatively higher backpressure handing capability and it will act like a conventional PSV.  If this leads to a catastrophic failure (chattering), it could be a very bad day at the factory.
