Is it necessary to control the pH of raw wastewater in sump tank? Does this idea can improve the wastewater quality?
Wastewater Treatment Plant Design
Started by , May 25 2006 08:52 PM
Posted 25 May 2006 - 08:52 PM
Posted 12 June 2006 - 01:44 AM
of course,if it is not necessary,can you make sure that your bacteria group will go on work?mostly the sump acts as a PH buffer,it can not be saved from the project investiment as well as a process device.
Posted 25 June 2006 - 09:09 PM
markhong,
Thank you.
Thank you.
Posted 28 June 2006 - 07:54 AM
While it may seem necessary, it is not often practical. The bugs that digest the waste are pretty hearty characters and will live just fine in typical wastewater. Further, the pH changes due to the biological processes. Usually it is the bugs that dictate the pH rather than the treatment plant. What gets you is if someone dumps several thousand gallons of say HCl...that causes great turmoil, but, since such instances are illegal (at least in the States) it dows not happen often.
Urea PlantStarted by Guest_MLGP_* , 20 Apr 2025 |
