Hi there.
I have NOx emission value in ppm but i want to convert it into ng/J as environmental agency limit is in ng/J.
I have calculated Stack gas flow (kg/hr) by assuming complete combustion, Molecular Wt of Fuel Gas and stack is also calculated.
Requested to kindly verify the calculations and unit used.
I have calculated Heat Input (J/hr) = LCV of Fuel (KCal/Nm3) * Vol. flow rate of Fuel gas(Nm3/hr)* 4186
Now i am confused regarding conversion of NOx in ppm to ng/ hr ... this is wht i did:
NOx (ppm) * Vol flow of Fuel (m3/hr) = NOx (mg/hr) .... Kindly note tht Vol flow unit are not Nm3/hr but m3/hr was used.
Then NOx (mg/hr) * 1000000 = NOx (ng/hr)
So Finally, NOx (ng/J) = NOx (ng/hr) / Heat Input (J/hr)
Nox Emission Value In Ppm To Be Converted Into Ng/j
Posted 03 December 2015 - 02:27 AM
Posted 03 December 2015 - 02:34 AM
Ankit,
Please note the following
ppm wt = mg/kg
ppm vol = ml/m3
when the density is 1000 kg/m3 then only 1 ppm = 1 mg/l
Posted 03 December 2015 - 03:36 AM
I think ppm vol = ml/m3 is for liquid only.
For gas(air pollutant) ppm vol= mg/m3
correct me if i m wrong ......
Posted 03 December 2015 - 04:21 AM
It is ppm i.e. parts per million.
It does't matter it is gas or liquid.
ppm wt = mg/kg
ppm vol = ml/m3
So use the aforementioned, and calculate.
If you want the change the numerator in terms of mass or volume you would require density of the fluid.
Burner For Emission LimitsStarted by Guest_srikar_* , 22 Apr 2019 |
Oxygen Content Converted To Methanol ContentStarted by Guest_Phenom_* , 09 Apr 2019 |
![]() Amine Storage Tank EmissionStarted by Guest_P Thakur_* , 08 Dec 2016 |
![]() Nox Emission CorrectionStarted by Guest_Elton_* , 03 Nov 2015 |
No2 Emission Measurement CalculationStarted by Guest_6chemprocess_* , 15 Sep 2015 |
